Water under passenger seat
Thanks for the input and debate I will have a look tomorrow as apparently its not going to rain. Strange thing is that the carpet next to the door is dry - I will let you know what I find tomorrow.
3.0SI, Black
- dhobbs
A lot of old cars the drain holes get blocked and the door starts to rust. Thank God for galvanised steel!
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
Been said a lot before but if all usual areas are ok the culprit can be blocked drain hole where the roof motor is located. the drain is difficult to clear on this side due to the motors location and water can start to fill in the housing and then spills over into the interior of the car behind the rear seat. So if it is really wet behind the passenger seat more than say the footwell this could be your answer. It is an area I will be investigating on my car as despite checking everything water is still getting in. I think the best step to take will be relocate the motor to the boot and then rod the drains.
OK Talc test done as lots of rain last night. Unfortunately no sign of any water
Ok what should I check next?
Ta
Kev
Ta
Kev
3.0SI, Black
- cj10jeeper
In order I'd do:Kbs133 wrote:OK Talc test done as lots of rain last night. Unfortunately no sign of any water
Ta
Kev
Front drains easily accessible from under bonnet
Rear drains
Windscreen
Ok. I will try the front drains. I am guessing there will be a how to on here.
3.0SI, Black
