top motor removal help
- rapidroy
hi all
i got up to this spot and the motor does not want to come out. any help?
- chapeau
The black hoses loop around the base of the motor housing in a clip and this and at least one cable tie need to be snipped before it will all come out. The link here shows the view of the housing from the side that might help (step 4). viewtopic.php?t=85266
E85. 2.5i SE. 2004. Sterling grey, anthracite 107s, black leather heated seats, hardtop, sound gen retrofit, matt black grills, stubby, zhp, cupholders retrofit, roof motor in boot.
- rapidroy
ya I've been reading that post for a week and just dove in today. the cover was a B word to get off then my arms are way to big so i'm working on getting my 14 year old grandson to help.
- chapeau
Its quite comical the position you end up in inside the boot just to access it. Smaller arms are definitely the way forward.
The hardest thing i found was snipping the cable tie holding the housing to the roof post. Once that was cut it started to move up and out, although was still quite difficult as the power cable and the pipe looped over the motor housing's bracket(you can see them going over to the left in the photo on step 4). When i pulled the housing up they needed to be moved round the bracket to allow it to come up enough to be pulled out otherwise it was too tight.
- rapidroy
WOW got it!!!! i enlisted my soninlaw to help and his endoscope from his work. Now i have a working top I couldn't have done it without your DIY
- Chris_D
We have a thread going here called 'daves' danglers' showing just how comical, but effective, Durham Dave looks when doing the motor relocation....chapeau wrote:Its quite comical the position you end up in inside the boot.
- rapidroy
does anyone have a pic of how much you need to cut for the lines for the relocation?
- chapeau
I didn't actually cut mine. I just lost the excess in the cavity under the roof, making sure it didn't get in the way of the roof dropping or get crushed.
- 20161014_175304.jpg (87.63 KiB) Viewed 1007 times
- rapidroy
I meant the plastic tray thing but your pic shows it. can you put your top down with key fob? i tried coding with pa soft but i only get the windows go 1/2 down and top down light flashing red when holding down the door unlock button on the key fob. and one more thing when closing top the back latch holds on till you can here the pump giving its all then with a slight pop to unlatch it starts to close. history is the car is new to me and the old owner said top stopped 3 or 4 years ago so i'm not sure if the latch just needs to loosen up alittle.
https://www.youtube.com/watch?v=JVsNLxbSmyc
the audio is my sister.
- tug
Hi, you dont need to cut anything, although you could cut a slight half moon into the top of the motor "well" as the lines pass over it. To have a nice finish to the job remove left roof shelf bracket, lay the motor in side pocket in boot then put the bracket back, this will hold the motor secure and keep the lines away from any roof operation.
Cheers, tug
Cheers, tug
E85 N46 2.0i SE BLACK SAPPHIRE
- rapidroy
i tucked the pump behind the carpet, looks ok to me
- P1080326.jpg (64.4 KiB) Viewed 950 times
- tug
Hi rapidroy, done that with mine also, did you run the lines behind the shelf backet? also mate you need a cover like this;
- rapidroy
I notched the tray and the hoses and wires go up through it. I'll need to make a cover next.
- chapeau
Well done on getting it done. It really does give piece of mind when it is raining like it is today.rapidroy wrote:I notched the tray and the hoses and wires go up through it. I'll need to make a cover next.
I made my cover from an old ford floormat. It was almost an exact colour match and stiff enough to stand up on its own with a little velcro to hold it to the existing boot carpet. It may not be perfect but i am happy enough with it.
- rapidroy
Rain here too, I got it done just in time
