Roof wont go down..
Roof wont go down..
Wonder if anyone can advise... checking my z (stored for winter in a garage)... tried to drop the roof , windows went down and roof unlatched and moves about 25mm back ... if I repress the roof down button I can hear a relay click..but no movement of the roof. It happened last year and post a couple of presses of the button it started working again. Noticed before I tried the roof, I took the battery off trickle charge and removed charger.. ignition on noticed clock had reset which I thought was strange also .. while on charge the boot had been left fully up ...
wonder if all is linked ... or is it the roof motor / pump... any checks or actions to prove out what is causing the fault ..
- Number5
Roof wont go down..
It sounds like the first half of the process is working. i.e.
1. Windows Drop, 2. Roof Detaches from Windscreen, and then part 3 is failing, whereby the hydraulic roof motor pulls the roof back.
Try keeping your finger on the button and giving it a gentle helping hand, which may get the motor running, but long term it sounds like your roof motor has/or is failing after sitting over winter. Time to investigate and relocate it I'm afraid.
( I assume that you dont have the flashing orange light on the switch, which would indicate the parcel shelf is in the wrong position?)
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Roof wont go down..
Thank you for the response ... i will double check the lower roof button led wasnt orange .. I believe is was red ... getting prices for motor and pump refurbished unit around the 250 mark .. supplied and fitted plus relocted to the boot around the 750 mark. Also informed to check drains first ... before progressing motor exchange ... funny thing is BMW dealer who I purchased the car from informed me that they changed the roof motor due an issue with it dropping / didn't go down straight and mark roll over hoops purchase purchase which they fitted. since then the car has only been washed and never used in the rain.
- Number5
Roof wont go down..
Is there any warranty on the motor they replaced that you can pursue ?
Dont go spending £750 at a dealer. There are people on here who will help you sort it for about £150 cash and usually if the motor has only just stopped working, its salvageable.
Where about's in the country are you ?
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Onlinebuzyg
Roof wont go down..
Not clear if your engine is running when you are trying this. I assume you are sure it's not a dying battery?
Roof wont go down..
Thank you for the replies guys .. I'm in Essex and did have the engine running when I tried. The car was an approved BMW about I purchased 3 years ago, all warranties have ran out.
Roof wont go down..
Daveyzz wrote:Thank you for the replies guys .. I'm in Essex and did have the engine running when I tried. The car was an approved BMW about I purchased 3 years ago, all warranties have ran out.
Roof motor can be fixed and relocated at the same time. I normally charge £60 for that.
Roof wont go down..
Thank you Marius,
- Number5
Roof wont go down..
£60. There you go Bargain !Daveyzz wrote:Thank you Marius,
Let us know how you get on.
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
2x E89's
- owm
Roof wont go down..
Wow...that is a good price
Speaking from experience doing it myself, I highly recommend letting a professional carry out the job
1977 Alfasud Sprint
1988 Mercedes Benz W126 300SE
1991 Mazda MX-5
1996 Rover Mini Cooper
2003 BMW Z4 3.0i
1991 Mazda MX-5
2003 BMW Z4 3.0i
- rapidroy
Roof wont go down..
I have a 2003 and I have to push and hold the down button for the whole prossess of top down and up. its not a 1 touch button like the windows. try holding the button down
Roof wont go down..
Same asrapidroy wrote:I have a 2003 and I have to push and hold the down button for the whole prossess of top down and up. its not a 1 touch button like the windows. try holding the button down
- markplant
Roof wont go down..
Roof isn't one touch as standard as it doesn't have anti trap like the windows do, it can be made one touch with a gap Tech module
Roof wont go down..
Is that a straight swap out module ??markplant wrote:Roof isn't one touch as standard as it doesn't have anti trap like the windows do, it can be made one touch with a gap Tech module
