Broken Springs - List (add yourself if you've been affected)
Onlineronk
Re: Broken Springs - List (add yourself if you've been affected)
That's nothing to do with the flat ends. It's the material and temper of the Spring unit.
Broken springs tend to show a typical stress fracture normally just after the first coil.
In reality its not that simple:-
https://pearl.plymouth.ac.uk/bitstream/ ... sequence=1
I've replaced all the springs on my E85 03 plate with thicker after market sports springs. The previous owner had told me he replaced the two rear springs. I had put the car away perfect for the winter and on getting it out the garage, the f/n/s snapped. Decided then to replace all. OEM's are very thin and fickle.
- nfbr
2007 3.0Si Coupé -
March 2010, Knocked on MOT for O/S/R Spring Fractured.
Both springs were replaced at this point.
July 2013, Knocked on service for O/S/R Spring, 'Pigtail' missing from bottom of spring.
Both springs were replaced again at this point.
January 2015, All four springs replaced with Eibach Pro-Kit
Original springs were in immaculate condition and sold on.
nfbr's 2007 BMW Z4 3.0si Sport Coupé - Car Diary/Blog/Build Thread
Ruby Black - Steptronic - Champagne Merino leather.
I like taking Photos, Cars, Technology and Rock Music
My car is an 08 3.0 SI Sport the springs were changed in 2014
My Cars
2021 X3 M Sport loaded with Tec
1974 Triumph TR6 in Mimosa Yellow
Gone but not forgotten
2008 Z4 3.0 SI Roadster
Re: Broken Springs - List (add yourself ifyou've been affected)
rear springs broken 2007 z4 70000mi last coil on bottom
Both rears broken passenger side snapped in the middle, drivers side snapped at the bottom, 2.5se 2004
Passenger side snapped st the bottom - both replaced
Having gone through the service history on my 2008/57 3.0si Sport, both rear spring were replaced separately (so presumably once they had broken) after less than 2 years/20k miles.
Looking through the service history of mine it's had 3 new springs on the rear, all done by the BMW main dealer where it was bought and serviced.
I decided to stick Eibachs on it and the first thing I noticed was that they'd fitted the latest OEM spring upside down. I wonder if this is incompetence (most likely) or if they've perhaps found that the springs don't snap as easily when fitted the wrong way up
Z4R 3.0si Sport auto. So far: 19" CSLs, Eibachs, MM exhaust tips, de-badged rear, stubby, black grilles, spacers, aux cable, interior LEDs, LED boot strip......
- elevensies
2008(58)
rear N/s x1
going to replace with lowered ones
rear N/s x1
- Zedster
Both springs fractured, being replaced for the second time in the cars life, otherwise MOT fail. Not bad for just under 40k miles!!!! BMW still refusing to acknowledge that this is an issue with a large number of our Z's.
SI Coupe Silver Grey
OSR spring found to be broken in usual place at just under 30k miles - 2004 3.0SE - replaced both rear springs with non OEM thicker springs.
Onlineronk
I don't think it's a Z4 issue - I've had broken helical springs on Audi, Saab, Vauxhall and Mercedes !Zedster wrote:Both springs fractured, being replaced for the second time in the cars life, otherwise MOT fail. Not bad for just under 40k miles!!!! BMW still refusing to acknowledge that this is an issue with a large number of our Z's.
- Zedster
I take your point. However I consider in my case, replacing the rear springs twice in under 40k miles to be excessive, and judging by the amount of debate on this particular thread, plenty of people agree.
- freakent
Yep, twice in the last couple of years. Failed MOT last time because of broken spring.
Z4 Roadster 2.5 SE - 2006 - Montego Blue - owned from new & still puts a smile on my face
