Drop me a message if you would like this done
Replacement Roof Motor Guy!!
Hi Bowser134
My Zed roof is stopping intermittently & is quite sluggish, can you contact me regarding price etc etc.
Kieron (hassocks, Sussex)
Sent you a messageKayjay1966 wrote: ↑Mon Jul 31, 2017 5:48 pm Hi Bowser134
Hi Bowser134,
My Z4 roof is in need of some help! Can you please send me a message?
Thanks in advance,
Jason
Thanks in advance,
Jason
Hi Bowser
My Z4 roof was sluggish but has now given up completely. Could you give me an idea regarding price etc.
Kevin
Kevin
Messages sent
Hi bowser134 - could you PM me your details. Wife's roof just stopped closing and we've been quoted a lot just to investigate further so would like to come see you instead
Matthew
Or indeed anyone with the contact details feel free to PM me
Im Newbury based
Matthew
Im Newbury based
- Number5
Hi Matsleight,matsleight wrote: ↑Tue Sep 05, 2017 3:08 pm Hi bowser134 - could you PM me your details. Wife's roof just stopped closing and we've been quoted a lot just to investigate further so would like to come see you instead
Matthew
Im Newbury based
I'm based in Bristol and can sort and relocate it for you. I'll PM you.
My z4 motor has also stopped working, releases but does not move. Anyone got contact number for bowser 134, heard good things on forum of his work.
Thanks Jon
Thanks Jon
Sent you a message Jon
Hey bowser134, my '08 z4 roof has stopped working too. The roof unlatches/latches but doesn't go up or down. Any chance you could help? Thanks
Hey bowser134,
Can you drop me your details please - I have a roof that needs fixing - based in east London.
Thanks!
Thanks!
Best bet is to have the motor moved out of the rear void it normally sits in to the boot area. Roof stays on for this and added bonus it can be topped up and swapped in an hour if it should fail for any other reason than water ingress.
Just drilling holes in the plastic cylinder the motor sits in will only work if the main drain is clear - if not it will flood with water at 1 inch deep instead of 8 inches.
See Mike in St Helens on here , moved for £80 while you wait an hour....contact mike at [email protected] he does key coding , exhaust box "growler" mod and can do dealer level programming with an i pad like device via your OBD socket on bluetooth. I had roof open AND close with remote on key and alarm audible set, silent un set.
- Ducklakeview
Thanks for the plug!MD99 wrote: ↑Mon Sep 25, 2017 11:37 pm Best bet is to have the motor moved out of the rear void it normally sits in to the boot area. Roof stays on for this and added bonus it can be topped up and swapped in an hour if it should fail for any other reason than water ingress.
Mike
