Probably not much help but i did this sort of thing years ago with a quick rack i fitted to a 205 gti. Made a big difference to the steering feel on the twisties etc but was a bitch to park, a really workout for the arms. Obviously this was a non power assisted system and I wouldn't have thought the steering would be too heavy with 2 1/2 turns verses 3 on a power steering system but will still be noticeably different. It will also be more twitchy on a motorway etc so i suppose it depends on what you want to use your car for predominately and what you personally like in terms of directness vs twitchiness and how much weight in the steering you find acceptable. Wouldn't the number of turns on an M Rack be a good guide to what works well on Z. Anyone known how many turns on one of these compared to a normal Z?Machine monkey wrote:Hummm stranded rack 3 turns £30 or purple tag one for £75!!!
Would 1/2 a turn lock to lock make that much difference??? Opinions please forum?
Sticky steering problem. Time to sort it! Help and advice.
- MACK
Re: Sticky steering problem. Time to sort it! Help and advice.
Silver 05 3.0i SE
White E89 20i M Sport
- Machine monkey
I think the zed is 2.5 turns already is it not?
I think i will be going for the cheap option of 3 turns anyway. It will probably help make the already snappy car less snappy when drifting. If i dont like it i can change it.
To be honest 1/2 a turn wont make that much difference, when I researched people changing racks on the Z3 people were going for purple racks for the positive feel through he steering, I just opted for the same, however you can get cheaper racks if you want to, the conversion wont be any different.
- MACK
Do the number of turns change on the electric Z4 rack between having the sport button on and off with some clever gearing etc or is it simply a steering weight thing?
Silver 05 3.0i SE
- GuidoK
It's a steering weight thing, how much the power assist supplies.
- Ewazix
I dug this out which gives a good explanation of the EPS
http://www.bmwclub.lv/files/06_E85_Chas ... cs.001.pdf
2018 Cooper S Countryman
Fiesta Ecoboost
Fiesta Ecoboost
- ianwill90
I am considering this conversion now too. I just wondered about the insurance poilcy, technically this is a modification, have any of you informed your insurance company, and if so what effect did it have on your policy premium?
Roadster 3.0i 2003 Silver. Manual. Original.
18" 135 Alloys, French Fries and Whippy Aerial.
I have the sticky steering issues, ok cold mornings but when it gets warm not ok etc....
So started the drilling and grease nipple mod... getting the drill depth right I'm unsure of, is the shaft running directly in the housing where you drill in, so there's no clearance between the two?....so when you drill you don't break through as such, because the shaft is immediately there? .... just goes hard to drill.
Hence needing grease under pressure to force its way in?
Looking in the hole, just looks like a blind hole, though it's gone difficult to drill etc.
..... So I stopped ...
Oh any links to pictures or videos that are still live? most seem dead now
57 Plate 3.0 Si Auto SilverGrey - Red Leather
E89 35iS Space Grey - Red Leather. SOLD
56 Plate 3.0 SI Manual - Black with Red Leather- Scorpion exhaust, BC coil overs SOLD
54 Plate 3.0 SE Auto - Silver with Red Leather. SOLD
- mr wilks
Have you been following this post ? viewtopic.php?f=3&t=85889&p=1270024#p12700249designs wrote:I have the sticky steering issues, ok cold mornings but when it gets warm not ok etc....
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Nope...different issue.....
I finished the nipple fix today, didn't have any grease, so it's only had a squirt of WD40 for now and on the bush through the bulkhead... Test drove and all ok.... No sticking.... Grease for a longer fix arrives in a couple of days.
Being 56 degrees north I have this issue maybe 3 or 4 times a year it is unsettling , however when one knows it a ' feature' of the early zeds one doesn't panic the car will be fine he next day .
2.5 Maldives Blue, tottaly original , no mods,
9designs wrote:Nope...different issue.....
Did you get past the hard part of when drilling ??? I seem to be in the same place you was on your last but one post ! I've drilled about 17mil in but it's gone really hrd to drill now ? From what I've been reading I need to drill about 38 Mil to get to the steering shaft so tomorrow I'm going to buy some decent drill bits and carry on, also would I be right in thinking once I'm through enough if I turn the steering wheel I should see the shaft moving through the hole ?
Steve
No the depth your at seems to be what people say is OK and you have reached the shaft when it goes hard to drill...so I stopped..
I'd like to see an assembly stripped down so I can see what's need...
That said I've grease it and all still ok.... Whether it was the bulk head bush or the hole I drilled I don't know... Either way seems sorted thankfully.
I'm not sure I've gone in enough ? Surely if I was to turn the wheel the shaft will move along with the small drill mark on the shaft ???
I expected the same, but that's not what I found...... by the fact it was near impossible to drill more, I had good bits, it must be on either a hardened shaft or hearing housing of some sort. I wouldn't fancy making a hole in either !! ... All the tips from people who have done it say stop when it gets hard to drill..... you're on your own if you keep going !!!
Without seeing a part stripped down or decent drawing I am little sceptical, but it worked so far.
