I have this image of loads of cars driving around with their arms up off the windscreen now as the cure for squeaky wipers lolronk wrote:Lift the arms off the screen - if the noise goes away it's in the arm.
Wiper squeak
- Mafoo
Re: Re: Wiper squeak
Z4 3.0i SE - gone but not forgotten
Need a Forum approved Specialist Independant Garage? viewtopic.php?f=4&t=38928
well its fixed my squeakMafoo wrote:I have this image of loads of cars driving around with their arms up off the windscreen now as the cure for squeaky wipers lolronk wrote:Lift the arms off the screen - if the noise goes away it's in the arm.
iJoke, oiling later so will report the results
- ronk
Re: Wiper squeak
put the oil on the pivot and spring loops!
I wish I was as confident of the lottery numbers tonight.
Re: Wiper squeak
yup, as i pulled the wiper up to wash the car just i got that horrible squeak so used some wd40 and job done
- ronk
Re: Wiper squeak
Liam-O wrote:yup, as i pulled the wiper up to wash the car just i got that horrible squeak so used some wd40 and job done
OIL!
Not that stuff - the noise will soon be back!
Wiper squeak
I've had the same. The problem with mine was... one end of the spring hooks over the pivot pin in the arm. Over time it has wandered to one end, this has put the body of the spring against the inner side of the arm. So when it extends and contracts it scratches on the arm, reverberates down the blade and then is amplified by the windscreen.
Solution: a squire of WD (be careful where it goes, you don't want it on the blade or screen) and lever the spring back to the centre of the pivot.
£70 Saved - lesson learnt!
Damian0797
BMW Z4 2003 2.5i manual
Jaguar X-type 2002 AWD 2.5 v6 sport
Suzuki Bandit
Suzuki Bandit
