Cracked Windscreen :(
So on Sunday on the way to my folk's house I got a stone chip, 2 in fact.
Queue a call to Autoglass on Monday the earliest they can come out was today. One chip was not great as it was on the inside of the window (which apparently is touch and go on resin injection). The second has spread to a 10 cm crack in the freeze.
Balls.
Just venting really. I wanted to drive the car on Saturday, but the replacement screen won't be in until Monday. I guess it's the Gf's knackered Civic for Saturday.
Balls.
2007 3.0si Coupe, LED interior lights, Stubby, ZHP, AC Schnitzers, 15mm spacers on the rear. 1993 Modified Pre-Cat TVR Griffith, Ducati Monster 821, MV Agusta F3 675
- obewan
I'm sure I've seen a thread on here about making sure you get the official BMW seals - may be worth a look
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
- ben g
The screen will be fine to drive with a crack in. It won't shatter as it's laminated glass.
Bmw windscreen surround is a must as the pattern part ones crack at the top edges. I have previous experience of this and my current one (i've had 3 windscreens fitted) has cracked slightly.
It's only a cosmetic seal, so doesn't affect anything, but it does look unsightly.
- Silverzedtom
I’d drive it still, like Ben said it’s not going to shatter. It might grow a few inches but it’s already broken.
E85 2.5si
F55 Cooper S
F55 Cooper S
- paddy wright
You can insist on bmw glass- I would as when mine done the fitter said he was glad it was official one as the others are a pain to fit.
My car had its screen replaced before I bought it and it developed a leak. Took BMW 5 weeks to work out this was the reason for the leak. Don't trust after market you want BMW screen and seals
- Stuartt
Plus one on the OEM windscreen seal
Autoglass fitted an after market screen which is fine.
Stuart
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
Autoglass on the way now. I have requested an OEM seal, but an oEM screen will be a while for a wait and I need the car for a fair bit of driving around over Christmas.
I'll keep an eye on it though an make sure I've got it warrantied.
- ben g
You do realise bmw don't make the windscreens? They're most likely manufactured by Pilkington who simply put a BMW badge on them.paddy wright wrote: ↑Sun Dec 17, 2017 10:14 pm You can insist on bmw glass- I would as when mine done the fitter said he was glad it was official one as the others are a pain to fit.
Therefore an 'aftermarket' Pilkington windscreen will be exactly the same.
Ok, good and bad.
Bad: Autoglass did not send an OEM trim and it basically looks awful. But the car is servicable.
Good: Technician was a Z4 owner and a biker. He was really embarasssed, called the office and has re-booked in asking for genuine parts all round and the Z will get an OEM screen with logo and OEM seal from BMW next week.
- paddy wright
I do realise bmw don’t make the majority of their components- however OEM are of a higher spec than aftermarket generally, and in terms of the screen I was just offering my experience where the professional who knows these things said they were far from the same.ben g wrote: ↑Mon Dec 18, 2017 10:21 amYou do realise bmw don't make the windscreens? They're most likely manufactured by Pilkington who simply put a BMW badge on them.paddy wright wrote: ↑Sun Dec 17, 2017 10:14 pm You can insist on bmw glass- I would as when mine done the fitter said he was glad it was official one as the others are a pain to fit.
