E85 Electric Power Steering Failure - Control Unit
- Rits83
Hi Guys
Went to jump in the Z4 on the weekend and the EPS light was on and the sport button was inoperable and I had no power steering. After taking it to my local BMW specialist they have diagnosed that the control unit on the EPS has failed. Has anyone else had this issue? Be keen to read about how you resolved it. I've been quoted around £2,400 for a brand new part from BMW which is out of the question.
Has anyone used these guys?
http://www.ecutesting.com/catalogue/bmw ... &model=658
Seems like a good solution as they offer an unlimited mileage warranty on the rebuilt part.
Thanks in advance
Thanks in advance
Current - BMW Z4 2003 3.0i E85
I’ve used them for an abs module repair. Excellent service, I would highly recommend
I've used them for a Vauxhall ECU.
Tested it and told us it could be repaired. Think it was about £160.
Sent it back next day. Perfect. Saved us a lot of money.
Recommend.
Russell
Recommend.
Russell
- markplant
ECU testing are highly recommend
- Machine monkey
If you fairly handy with tools just swap to a hydraulic set up. Ditch the electric steering its rubbish anyway.
What's the approx cost assuming DIY labour to do the job?Machine monkey wrote: ↑Fri Dec 08, 2017 10:10 am If you fairly handy with tools just swap to a hydraulic set up. Ditch the electric steering its rubbish anyway.
viewtopic.php?f=2&t=92858 the intermediate shaft is the most costly part
- Machine monkey
Think mine came in really cheap around a few hundred quid. But i brought all second hand parts. Reconditioned bits the price goes up. And you may want to buy new lines. And the biggest cost is the M intermediary shaft?LordOxygen wrote: ↑Fri Dec 08, 2017 10:27 amWhat's the approx cost assuming DIY labour to do the job?Machine monkey wrote: ↑Fri Dec 08, 2017 10:10 am If you fairly handy with tools just swap to a hydraulic set up. Ditch the electric steering its rubbish anyway.
You also want a purple tag rack.
I'll throw my hat in here as another hydraulic convert. It's a reasonably simple job on the M54 engined model, which I'm assuming you have due to your sig!
All the parts bar the intermediate shaft come from the E46 3 series, intermediate came from a Z4M as mentioned before.
Total cost for myself was approx. £500 diy I believe, that included reconditioned rack and pump, with the rest second hand. All new bolts etc as required.
I didn't rush at all and took a weekend, no issue at all. Could easily be done in a day if desired.
- Magicarcher
When happens with warning lights if the EPS is not connected to the can network? Does the car not keep throwing errors?Machine monkey wrote: ↑Fri Dec 08, 2017 10:10 am If you fairly handy with tools just swap to a hydraulic set up. Ditch the electric steering its rubbish anyway.
Z4 3.0L 2005. Titan Silver. Audio Upgrade Second Stereo Pioneer X8700DAB, Sony Xplode 4 x 70W Amp, 6.5" Reckhorn Subs in rear cubby, Focal AS165-3 in fronts.
- Rits83
Quick Update - Took the car to Forza GB - as expected they diagnosed a EPS Control unit failure. Sent the unit off to ECU Testing who rebuilt the unit with a 4 day turn around time. Unit then re-fitted and EPS is back working. Superb job by Forza GB once again. 15% forum discount applied aswell.
- dario
what sort of money was the repair if you don't mind saying?Rits83 wrote: ↑Wed Dec 27, 2017 6:17 pm Quick Update - Took the car to Forza GB - as expected they diagnosed a EPS Control unit failure. Sent the unit off to ECU Testing who rebuilt the unit with a 4 day turn around time. Unit then re-fitted and EPS is back working. Superb job by Forza GB once again. 15% forum discount applied aswell.
- Rits83
£370 for ECU Testing and £190 labour @ FORZA GB - inc VAT & Postage etc
- dario
mjennings23,
Hi. I'm thinking of doing the same to my 2003 Z4. Do you have any advice/instructions on how you did the conversion please?
Paul
Paul
