Not feeling this was a stellar purchase.
So today was paintball day.
Derailed early on by.
Yellow handbrake light
Traction control light
Yellow tyre light.
No difference in running or stopping at all. Literally whilst cruising at 50.
Anyone had this at all.
Yellow tyre light.
MR-2 Turbo Rev2
Yep no Z yet. On the hunt.
- paddy wright
I think thats normally the indicator for a failed abs pump.
- groovy_hippy
I think Paddy is correct... mine went due to an emergency stop... but was fixed under stealer warranty. Not sure how much the job costs to fix through a non-stealer route...
Current ... 2007 Z4 Coupe 3.0si Sport | Manual | Alpine White | Black leather | Piano black dash
Intro to Zeds, now sold... 2007 Z4 2.5i SE Roadster | Manual | Stratus Grey | Red Leather | CDV delete | DLV backbox
- Mr Tidy
Sorry to hear your news OP.
But if it is the ABS pump these people have had good reviews by members:-
http://www.ecutesting.com/catalogue/bmw ... &model=658
Good luck getting it sorted.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
When did you purchase? Private or trade?
- Ducklakeview
Yup, sounds like ABS pump - If you don't have a code reader, try slamming on where safe and see if you get a wheel locking up..
If you do have a reader, the codes will probably be;
5DF0 - hydraulic unit pump motor and
5DF1 - hydraulic unit pump motor connector
In which case it can be repaired, in about 2 1/2 hours including removal, refitting and bleeding.
Mike
Mike
- markeg
Could be ABS sensor, mine was. OEM sensor £100, and an easy fix
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- mr.tourette
be nice if it was..had these lights pop up on my daily was and it was indeed a sensor..relatively cheap fix, not quite sure why everyone always assumes it has to be the abs pump..do that many go pear shaped on zeds?
- GuidoK
Probably just as much as sensors go. Also a known issue.
Thats why diagnosing starts with code reading and not with guessing
Bit more about the scenario. The abs was indeed working approx 10mins prior to this. It went off when I stamped the brake to avoid a cat in the road and worked as intended. Then an extra 90kgs was added to the car in luggage and a passenger. The brake that fired the abs is knackered, the caliper is pissed so I'm guessing it's cooked the abs ring for that wheel.
Anyway I'm tired of guessing. I've ordered a diagnostic tool i910 from Bavarian Dominator to pull the info. If it's a ring / sensor epic £22 fix. If it's pump it's off to Mike for a pump repair and roof motor relocation.
Will update when the kit arrives.
MR-2 Turbo Rev2
- Ducklakeview
The abs ring won't be affected by the caliper. Code read definitely needed.Monkeydonkeyratmagic wrote: ↑Mon Nov 20, 2017 8:42 am Bit more about the scenario. The abs was indeed working approx 10mins prior to this. It went off when I stamped the brake to avoid a cat in the road and worked as intended. Then an extra 90kgs was added to the car in luggage and a passenger. The brake that fired the abs is knackered, the caliper is pissed so I'm guessing it's cooked the abs ring for that wheel.
Mike
I havo no hesitation in recommending Mike (Ducklakeview) if your abs pump needs repairing. Mike repaired mine last Saturday in a couple of hours and now works perfectly.
- 85genius
Mine started doing that when the battery was knackered and was fixed by fitting a new one (£50 from Tanya) most garages or tyre shops will do a free battery check so that where I'd start especially if you have had any other random warning lights or electrical gremlins.Monkeydonkeyratmagic wrote: ↑Sun Nov 19, 2017 6:55 pm So today was paintball day.
Yellow tyre light.
These cars particularly earlier models don't take well to a weak battery for some reason
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Quick update before my scanner comes tomorrow.
Abs is working on all wheels. Took a while but I got it to work on all 4 wheels several times. (Scabby bit of road covered in man holes, wet, stamp brake feel results) should be interesting.
MR-2 Turbo Rev2
Again I ask, How long have you had the car, private or trade sale?
