03 2.5 not starting
zagamuffin
03 2.5 not starting
Post by zagamuffin » Tue Oct 24, 2017 7:04 pm
Hi lads
Went out this morning and car wouldn’t start, threw up the following codes
P0160
P0162
P2272
Would I be right in saying o2 sensor and I’m oxo .anyone else have this issue please
2003 2.5 silvery goldish
gaptech,19" ispiris,iPod kit,xcite halos,load of petrol
srhutch
Moderator
Moderator
03 2.5 not starting
Post by srhutch » Tue Oct 24, 2017 9:49 pm
Is it turning over?
Are the ignition lights on?
I don’t think an O2 sensor will stop the car from starting. Could easily be the ignition switch, but as said other than not starting what can you tell us?
ph001
03 2.5 not starting
Post by ph001 » Tue Oct 24, 2017 9:54 pm
Agreed, all those codes are O2 sensor related which aren't used at startup. If not turning over it eill be either starter motor (give it a tap with a wooden mallet) or the ignition switch.
zagamuffin
03 2.5 not starting
Post by zagamuffin » Tue Oct 24, 2017 9:57 pm
Car is spinning over fine , started for a sec this morning lumpy and then died , when turned over now it gives a slight splutter but no start
Is the ignition switch a known fault ???
Easy fix ???
ph001
03 2.5 not starting
Post by ph001 » Tue Oct 24, 2017 10:02 pm
No, if it's turning over ok it's not likely to be either of those. I'm assuming you have enough fuel in, in which case fuel pump / fuel pressure related maybe. When did you last fill up?
When you switch the ignition on, can you hear the fuel pump priming as normal?
zagamuffin
03 2.5 not starting
Post by zagamuffin » Tue Oct 24, 2017 10:25 pm
Didn’t check pump yet . Thought the obd codes would do the hard work for me lol
zagamuffin
03 2.5 not starting
Post by zagamuffin » Tue Oct 24, 2017 10:40 pm
Is it an in tank or external
zagamuffin
03 2.5 not starting
Post by zagamuffin » Wed Oct 25, 2017 5:28 pm
Tried turning on and off the ignition to check the switch and lights lite up everytime, sounds like the switch may be all right
Focusing on pump now , can you get at wiring in car to check for power , don’t hear it priming but can’t ever remember hearing it
I’ll jack it and have a look now
andyfanshawe
03 2.5 not starting
Post by andyfanshawe » Wed Oct 25, 2017 5:43 pm
We can do better than this!
Accelerator pedal to the floor, hold it there, and crank engine. If it fires, let throttle go. Its a quick clear flood. Repeat once or twice.
If youve got any carb cleaner or wd40 or easy start, pop air cleaner lid off and squirt any of the above in while someone cranks. If it tries to fire, you have a fuel issue. If not, most likely spark.
Quick and dirty checks as a start.
Andy.
zagamuffin
03 2.5 not starting
Post by zagamuffin » Wed Oct 25, 2017 5:49 pm
Tks for taking the time to answer
I’ll try that :D
zagamuffin
03 2.5 not starting
Post by zagamuffin » Wed Oct 25, 2017 6:33 pm
Andy
You are THE MAN
Tks a lot , very easy fix when you know how , soun started on full throttle and started straight away with air box open
Wonder what caused it , never failed before
Smartbear
03 2.5 not starting
Post by Smartbear » Wed Oct 25, 2017 6:36 pm
Good to hear it’s running, when did it last have new plugs?
e85 3.0si sold
zagamuffin
03 2.5 not starting
Post by zagamuffin » Wed Oct 25, 2017 6:47 pm
15k in my ownership
Smartbear
03 2.5 not starting
Post by Smartbear » Wed Oct 25, 2017 6:54 pm
zagamuffin wrote: Wed Oct 25, 2017 6:47 pm 15k in my ownership
How about previous to your ownership?
e85 3.0si sold
zagamuffin
03 2.5 not starting
Post by zagamuffin » Wed Oct 25, 2017 7:37 pm
I was told Serviced before I bought but could be bull ,
