indicators flashing fast
if anyone could help it would be great
the indicators on the right side of my 2003 z4 flash about twice as fast as the left ones
the bulbs are all good , seating good , corrosion free , the holders look good , so i am
lost what may be wrong , can anyone advise me please ?
thanks in advance
Richard
thanks in advance
Richard
First thought.. earth fault.
You say corrosion free, have you checked all sockets for good wiring and no water ingress?
- pvr
If the indicators flash quicker it means a bulb is out. Check the side lights for example.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
You say the bulbs are good but it's worth swapping them over (only the fronts and rears as sides are not monitored) and seeing if the fault follows. Can sometimes pick up a bulb on its way out.
- ranski
Also happens if the indicator bulb holder isn’t twisted into place correctly
Z4 3.0 / Mods done... too many to mention
And I forgot to add there are two bulbs at the front.
checked all bulbs , swapped them left to right and still same problem
its driving me mad now , anyone any ideas ?
thanks
thanks
- Coffee331
I had this problem before on the right side indicator.
Do yours flash ok when you just have the hazards on?
yes both sides same when hazzard lights on , just when on right hand indicator it flashes twice as fast
any idea
any idea
- Coffee331
I had the same exact issue...turned out, (at least on my car) to be the body control module was acting up. It was replaced with a second hand unit, was about £50 I think and some programming by my indy.
thanks , please can you tell me how it was diagnosed , ie how did you get to know what was at fault
thanks
thanks
- Coffee331
It was a simple as my mechanic had seen it before. He is a bmw specialist and essentially told me what it was within 5 seconds of looking at the car. According to him it’s not that unusual of an issue.
so is it just a matter of fitting a new unit , or does it need some sort of programming ?
is it a diy job
thanks again
is it a diy job
thanks again
- Coffee331
You could physically install the unit yourself very easily but yes there is a small amount of programming. I was getting another job done at the time and the mechanic didn’t even charge me to code the BCU, so it can’t be a big job.
Can you tell me where the unit is located ?
Thanks again
Thanks again
