Rattling doors - FIXED!
- ph001
Hey all, got a little bit of an annoyance with the Z4 - basically there is a rattle coming from both the drivers and passenger doors. This goes away if the doors are locked so I am guessing it's something in or around the latch mechanism. I was actually just going to code the doors to lock at a particular speed to get around this but obviously not a cure. Any ideas?
Rattling doors
Just check the nuts holding the crash bars in the doors. Open the door and you will see a plastic lug by the hinges, remove and there is a nut underneath it. I found my drivers side loose..after stripping the door down
Worth checking 1st
Worth checking 1st
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- patriot66
Rattling doors
Fairly certain this will be the door lock pins rattling in their escutcheons. Mine drove me potty ! Unscrew the pins and wrap a few turns of black insulating tape around them. A bit of trial and error until they are snug but not binding when you lock/unlock the doors. Easy fix !
- ph001
Rattling doors
Both great inputs...thanks.
- ph001
Rattling doors
Hmmm those door lock pins don't come out easy. Are they supposed to just unscrew?
- ph001
Rattling doors
Had some more thoughts on this overnight. I think the little plastic outer clips (which the pins sit in) just pop out of the door trim much easier than the door lock pins come off. I'm going to remove the outer clips and glue a small rubber o-ring into each. Will take pics as I do it.
- Paulr
Rattling doors
Please do, mine are driving me nuts! Tried doing the insulating tape thing, but is it when the car is locked they rattle, and I don't want to see insulting tape on the pins when unlocked!
If you try and take a cat apart the first thing you have is a non working cat.
- ph001
Rattling doors
UPDATE - completely eliminated the door rattle over the weekend.
I used a door trim removal tool to prise the escutcheons up out of the door trim (they are pretty tough to get out and you will inevitable break one of the retaining lugs). Once out, you can see that the part has three small plastic internal prongs (I have marked with green dots) which are supposed to locate against the door pin to stop any rattle. One of mine only had one of these prongs left and on the other one all the prongs were weak and not really touching the door pin. I guess new escutcheons would sort for a while but the design is fundamentally a bit poor. (BMW part no.51417042868)
I cut off the internal prongs and added a thin slice of self adhesive velcro hoop material to the inside of each escutcheon. Then simply pop the escutcheons back into the door trim and you should get a lovely snug but relatively friction free fit against the pins. It didn't seem to matter that a retaining clip had broke off on extraction - they still snap in very positively. Rattling completely gone and totally invisible from the outside.
- Paulr
Right! I know what I am doing later! Thanks for that, wondered how they came out!
- MrPT
whoa.escutcheons
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
same as what i did,
the original design has a foam pad in the door that pushes the rod tight against one side of the pin holder. The foam eventually wears and becomes loose.
https://www.youtube.com/watch?v=Djgcv-VpCW8
you can just see it at the 5:00 mark on there
- ph001
Haha! Wasn't me who named them that...but I quite like it!
