Air Conditioning not ice cold, but was the day before
mattgecko
Post by mattgecko » Wed Sep 06, 2017 3:45 pm
2007 3.0SI, had the car for 2yrs (problem free, until now). No work has been done on the car.....
The A/C has always blown ICE COLD, running it on high would freeze me out.
Yesterday I went for a drive , the A/C was cool at best, not cold at all. I exercised the temp knob and it does go to heat and back to cooling.
2007 Z4 3.0 SI "sport"
Rusky
Post by Rusky » Thu Sep 07, 2017 3:40 pm
I take it that you have got cooling selected and not accidentally turned it off? :thumbsup:
3.0l Silver SMG, whippy and ginge fringe/ Sound gen mod/ Media bridge fitted (bluetooth and audio streaming) / Clear third break light/ Hard Top/ Eibachs springs and DLV back box/ Roof motor in the boot/ plus lots more.
mattgecko
Post by mattgecko » Thu Sep 07, 2017 3:49 pm
LOL... yes, I know the snow flake button.
Played around with it more... Climent controls, blower fan, knobs / buttons work as normal. Vent vs snowflake, it definitely gets cooler when snow flake is engaged. Used an OBD2 code reader and that was all ok (no codes)
I'll check fuses next and have the the system pressure tested, though if it were low on Freon the compressor would kick on and off or not come on at all. That isn't happening.
hopz121
Post by hopz121 » Thu Sep 07, 2017 6:20 pm
maybe it just needs topping up mate, go to have to re gassed :thumbsup:
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Ducklakeview
Post by Ducklakeview » Thu Sep 07, 2017 6:22 pm
Compressor will still kick in with as little as 50g of the correct 740g charge, as long as the pressure in the system is sufficient.
It's not a pressure check you need, the refrigerant needs to be evacuated and weighed to see how much is actually in there. Don't waste your time with the top up canisters. Have it done properly.
I can do it for you if you are local to WA9.
Mike
mattgecko
Post by mattgecko » Thu Sep 07, 2017 8:20 pm
Thanks for recommendations. A co-worker does automotive A/C on the side, I'll have it checked and filled as needed.
Thanks for the offer, I'm state side (California).
Matt
Ducklakeview
Post by Ducklakeview » Thu Sep 07, 2017 8:38 pm
mattgecko wrote: Thu Sep 07, 2017 8:20 pm Thanks for recommendations. A co-worker does automotive A/C on the side, I'll have it checked and filled as needed.
Matt
Just a little bit too far away then! :D
Mike
