Anybody know what this is?
Recently bought a 57 Z4 sport 2.0 and not long after started noticing spots of oil on my drive.
Finally got round to having a poke around under the bonnet and I think I've found the culprit but i have no clue what it is...
https://www.dropbox.com/sh/lvuln6k1lp1k ... faG6a?dl=0
Any ideas??
Any ideas??
you mean the big black cap, under that is where the oil filter is
- cj10jeeper
What a leak for there might mean? Well if oil is leaking from the oil filter housing then you'd do well to check it's tightened up correctly.
My concern would be that if you are getting spots of oil on the drive then it has been leaking a lot as normally it would be caught on the undertray
Clean the housing and see where the leak is actually coming from and if you are unsure of what to do get into a local garage. It's just messy not serious to the engine
Jaguar F-Type 3.0 Supercharged V6 S, Stratus Grey, LSD, Active Exhaust, CF wheels, Performance brakes, Sports seats and mods ongoing
Gone but not forgotten Z4 3.0i SE Roadster ///M front, Red ///M leather seats, Aero sills
cj10jeeper wrote: ↑Sat Jun 24, 2017 6:15 pm What a leak for there might mean? Well if oil is leaking from the oil filter housing then you'd do well to check it's tightened up correctly.
Nice one! I'll get the hammer out in the morning and remove it! It does look like its leaking pretty bad as there are pools of oil in the various cavities around the engine below it. I'll clean it up and see if i can tighten it tomorrow. Now I know what it is, it doesn't sound like anything too major...
Thanks for your help, appreciate it
When was the oil last changed??
I would do an oil and filter change, you get new oil filter housing seals with the new filter.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- patriot66
If oil is leaking from the join between the alloy filter housing and the black plastic cap then it's highly likely the 'o'ring seal is damaged/missing. As mentioned by firebobby you get a new 'o' ring in the box with a new oil filter. There's no point in just tightening the cap itself without checking first. Don't over tighten the cap, 25Nm as written on it. If it's not the 'o'ring then it will probably be the oil filter housing gasket itself...a much bigger job altogether unfortunately.
If the leek looks lower, i have heard the lower seals can go
http://bmwfans.info/parts-catalog/E85/E ... exchanger/
part 5/6
part 5/6
patriot66 wrote: ↑Sat Jun 24, 2017 9:13 pm If oil is leaking from the join between the alloy filter housing and the black plastic cap then it's highly likely the 'o'ring seal is damaged/missing. As mentioned by firebobby you get a new 'o' ring in the box with a new oil filter. There's no point in just tightening the cap itself without checking first. Don't over tighten the cap, 25Nm as written on it. If it's not the 'o'ring then it will probably be the oil filter housing gasket itself...a much bigger job altogether unfortunately.
it looks like its lower than the O ring, it's where the housing meets the engine. I have no idea when the filter was last changed either so I guess its its time to get it in the garage
biojo wrote: ↑Sun Jun 25, 2017 3:00 pm If the leek looks lower, i have heard the lower seals can go
part 5/6
Thanks for the Link, id say its probably part number 6 on that diagram.
Any of you guys got a rough idea what a garage will charge to fix this type of thing just so i know what to expect?
