Should make no difference i.m.o.Dogmatic6 wrote:My last inspection 2 was at an indy which included Eibach springs and allignment so not sure a main dealer would be interested in my problem after that.....
Broken Strut Brace :( ** FIXED **
- AlanJ
Re: Broken Strut Brace :(
///M tri colour steering wheel, mud flaps and loads of other extras! ZHP illuminated gear lever..... Pre Purchase Checks,Getting the Best out of Dealers http://www.bmwz4roadster.net
- Stuart Truman
Dealers are coin operated machines. You put money in, they stay interested!Dogmatic6 wrote:
My last inspection 2 was at an indy which included Eibach springs and allignment so not sure a main dealer would be interested in my problem after that?
Add yourself to the Z4 Map HERE! Instructions HERE!
Z4M Roadster, Imola Red, with Stubby and Intravee II. Low Miles per Gallon, High Smiles per Gallon
Previously Alpina Roadster S #69 Alpina Blue
- exdos
The fact that these brackets fracture on the OEM diagonal braces indicates that a strutbrace, which connects the two suspension towers together, must serve some purpose to improve handling.
- Adamski
Even a loose bolt on the diagonal brace will cause a lot of creaking, which indicates that the brace is maintaining rigidity
Gone: Z4M Coupé|Black Sapphire|OEM CSLs|Aero Skirts|OEM Strut Brace|Nav|Heated Seats|Logic 7 Pro Hi-fi|Bluetooth|Carbon Leather|PDC|BMW Assist|Stubby
Gone: Cherished 2003 3.0i Black Sapphire Roadster
Thanks all.
Took the car to a local small garage this morning, they rebuilt my front caliper around 6 mnths ago.
I'm going back on Mon or Tues to get it welded for around £30
I'm sure the cars not handling as well but that could be in my head...lol anyway its getting sorted.
Cheers
Cheers
Z4M Silver Grey with Red Leather
- Bing
Is there a torque value for the nuts on either end of the braces ? I am getting a creak occasionally that I think may be a nut that is not tight enough, but I don't want to over-torque them...
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
Previous... 3.0Si Sport Roadster, Black Sapphire, Dream Red leather with lots of toys and lots of mods...
Hi Bing,Bing wrote:Is there a torque value for the nuts on either end of the braces ? I am getting a creak occasionally that I think may be a nut that is not tight enough, but I don't want to over-torque them...
I found the below in another thread, hopefully someone will confirm its correct
45ft lbs for the larger nuts on the brace it's self. I can't recall exactly what the suspension tower ones were but it was low, around 25 -30 I think
- Bing
Dogmatic6, thanks - appreciated
That's 61nm, right ?
I just want to do the brace ones - not touching the tower bolts, best left well alone by someone as hamfisted as me
Re: Broken Strut Brace :( **Fixed**
Hi All,
Thats my strut brace tab/bracket fixed. Local garage welded it this morning for £30 they also dropped the shock mount underneath in case the heat from the welder damaged it.
Here's an updated pic
https://skydrive.live.com/redir?resid=7 ... Annui8G1dg
Cheers
Cheers
- Disca
Re: Broken Strut Brace :( ** FIXED **
Just found this thread, dealer pointed out mine had also snapped while it was with them for other work.
Waiting for the dealership to confirm whether the AUC warranty will cover it (it better damned do).
Snapped in a pretty much identical place to the images on the skydrive!
He who has the most toys, wins.
‘15 VFR1200FD
‘15 VFR1200FD
- srhutch
- Moderator
Has to be covered, there is no way I would pay whilst under warranty.
- Disca
I agree.srhutch wrote:Has to be covered, there is no way I would pay whilst under warranty.
‘15 VFR1200FD
‘15 VFR1200FD
Well my bracket ended up cracking again around a year or so later in a different place on the same bracket. I ended up buying two replacement brackets from the dealer and getting a local garage to replace themDisca wrote:Just found this thread, dealer pointed out mine had also snapped while it was with them for other work.
As my car hasn't been near a main dealer in 4yrs I didn't even try to get it done on goodwill lol
- Disca
The dealership said it will be quite a bit of bodywork to fix it so not sure what they plan on doing. They are rather elusive at present as always when I chase them though.Dogmatic6 wrote:Well my bracket ended up cracking again around a year or so later in a different place on the same bracket. I ended up buying two replacement brackets from the dealer and getting a local garage to replace themDisca wrote:Just found this thread, dealer pointed out mine had also snapped while it was with them for other work.
‘15 VFR1200FD
‘15 VFR1200FD
- srhutch
- Moderator
It's not normally the strut bar itself that fails but the welds on the bracket on the tower.
