How To: Interior and Rear License Plate LEDs
- TomHitmanHatton
Re: How To: Interior and Rear License Plate LEDs
It was discussed on another post. Give me a minute and I'll find it.
- TomHitmanHatton
This topic http://www.z4-forum.com/forum/viewtopic.php?f=2&t=25453
Post no.3
I can also recommend joe from Sopers of Lincoln (great service)
If you install this can I have a picture of before and after as I am also thinking of fitting
Post no.3
- srhutch
- Moderator
If you get the ones on the left, the 8 SMD ones you just use the existing bulb holder, no special holder required.Daaaavvveee wrote:Just ordered them, the license plate LED ones, you say a special holder is needed? Any idea on part? ThanksTomHitmanHatton wrote:I ordered mine from this company. I think it was this set http://www.ebay.co.uk/itm/8-XENON-WHITE ... 3ccfa1a559
- TomHitmanHatton
Just pull out the old halogen bulbs and replace with LED. The centre lights are tricky to get out.
The license plate needs a special housing
- TomHitmanHatton
Give me a minute and I'll do a picture
- TomHitmanHatton
- TomHitmanHatton
- srhutch
- Moderator
As per my post above, no special housing if you buy the right LED'sTomHitmanHatton wrote:Just pull out the old halogen bulbs and replace with LED. The centre lights are tricky to get out.
Is there a guide anywhere on how to get the damn housing from the central windscreen light out?
- half
I put the ceiling of 3.0. It is the same as yours and I put the LEDs. Only problem is that the fading has been lost a bit. So I put the old bulb.
- TomHitmanHatton
I haven't had any issues with fading
- half
To me it does fade until mid then turns off suddenly uff
Changed all my bulbs now apart from the dome above the gear knob
I had it off but the leds are too big to fit in the hole (ooo arrr!) so was wondering if anyone had any techniques or tips? Or is it simply a case of ordering different leds lol
Z4 now sold
Current - M235i
Current - M235i
theres two phillips screws on the back of the lamp unit to remove the perspex part of the light, remove these insert bulb inside crystal part and reinstall perspex.
18 Z4s owned to date.
Current: 2.5i Titan silver
I've got the unit off now and can't see any screws?
- IMG_7650.JPG (704.73 KiB) Viewed 5762 times
Z4 now sold
Current - M235i
Current - M235i
