Where's the best place for a front end lift with a trolley jack as iam about to paint brake callipers I ve found the rear jacking point on this forum ,also found the side lift on hear to , the car is a 2007 m roadster in silver grey mettlaic toying with the idea of lime green ,also poss de badging as might be two many colours with the M badge is this an easy job or will the paint behind badge look totally different even if I use t cut your thoughts please and any picks re jacking points would be apprechatied
