Half Colin
Having just sorted out the hardware & software necessary to connect my laptop to the car I thought I would list the Car Key Memory (CKM) settings that can be programmed into the car and or key(s).
The list shows the function and whether it's a Car, Key or Car & Key variable together with the available settings. Where there's a key option, up to 4 keys can be programmed individually. The factory default setting is highlighted in red.
I've just changed my clock to the 24hrs display and set 'Lock on drive off' so feeling quite pleased with myself.
Whilst I doubt if most people would want to do this themselves it does show what they can get programmed by the dealers.
ANTI THEFT SYSTEM
ANTI THEFT SYSTEM
- Interior Sensor (Car)
- Active
Not Active
- Active
- Tilt Sensor
- Active
Not Active
- Active
- Visual Disarming (Car)
- Active
Not Active
- Active
- Visual Arming (Car)
- Active
Not Active
- Active
- Visual Arming Lids Closed (Car)
- Active
Not Active
- Active
- Interior Light (Car)
- Active
Not Active
- Active
- Open tailgate (Car)
- Active
Not Active
- Active
- Lock After Unlock Without Open (Car)
- Active
Not Active
- Active
- Lock After Drive Off (Car & Key)
- Active
Not Active
- Active
- Double Unlock With Centerlock (Car)
- Active
Not Active
- Active
- Selective Central Locking (Car & Key)
- Not Active
Easy Entry
- Not Active
- 1 Touch Open Driver Side (Car)
- Active
Not Active
- Active
- 1 Touch Open Pass Side (Car)
- Active
Not Active
- Active
- Interior Light On With Unlock (Car)
- Active
Not Active
- Active
- Interior Light On With Term R Off (Car)
- Active
Not Active
- Active
- Soft On/Off (Car)
- Active
Not Active
- Active
- Daytime Running Light ECE (Car)
- Active
Not Active
- Active
- Home Lights, Time Period (Car)
- Not Active
40s
90s
150s
240s
- Not Active
- 1 Touch Funct Turn Signal Flash (Car)
- 1 x Flashing
3 x Flashing
- 1 x Flashing
- Auto Drive Lights (Set Threshold) (Car)
- Sensitive
Normal
- Sensitive
- Rain Sensor (Car)
- Active
Not Active
- Active
- Ignition Key Warning (Car)
- Active
Not Active
- Active
- Key Specific Set of Heat, AC, Vent (Car)
- Active
Not Active
- Active
- Fan Correction (Key)
- Increase
Not Active
Decrease
- Increase
- Flaps Setpoint Correction (Key)
- +3 Degrees
+2 Degrees
+1 Degrees
Not Active
-1 Degrees
-2 Degrees
-3 Degrees
- +3 Degrees
- A/C Operation On With Ignition (Key)
- Active
Not Active
- Active
- Closed Footwell Flap (Key)
- Active
Not Active
- Active
- Recirculated Air Memory (Car)
- Active
Not Active
- Active
- Seat Adjustment (Car)
- After Unlocking And Door Opening
After Unlocking With Remote Control
Not Active
- Consumption (Car)
- litres/100km
mpg(UK)
mpg(US)
km/litre
- litres/100km
- Distance (Car)
- Kilometres
Miles
- Kilometres
- Time (Car)
- 12 Hours
24 Hours
- 12 Hours
- Temperature (Car)
- Degrees Celsius
Degrees Fahrenheit
- Degrees Celsius
- Key Specific Setting Of Audio/Video (Car)
- Active
Not Active
- Active
- Switch-On Signal (Car)
- Active
Not Active
- Active
