Considering the plethorah of tools I rifle through trying to find the right size whenever I'm doing something on the Zed, and because the TIS doesn't seem it beneficial to list the required tools for a job, I thought I'd create this list.
I know I'll find it useful, which is why I'm doing it, but I thought I'd share it here, rather than save it as a text document on my machine, just incase anyone else would benefit.
This list should be considered a *living* list, meaning that as and when I find them, I'll update this first post and add more tools and sizes to it. If you have any that are not listed, then please comment away and I'll add them.
Hopefully, one day, we'll have a complete reference
anyways, here's the list so far:
BMW Z4 Toolbox Contents:
- AUDIO
- Business CD Headunit Mountings - Medium Pozidriv Screwdriver
- Rear wing aerial mount - 5mm Allen key
- BRAKES
- Brake Disc Guide Bolt - 6mm Allen key
- Caliper Guide Bolts - 7mm Allen key
- Caliper Carrier Guide Bolts - 16mm Spanner
- OIL SYSTEM
- Oil Filter Canister Cap - 36mm Socket / Spanner
- Oil Sump Inspection Hatch - Medium Posidriv Screwdriver
- Oil Sump Plug - 17mm Socket
- UNDER BONNET ELECTRONICS
- Fuse Box Lid Bolts - 8mm Allen key
- WIPERS
- Wiper Arm Securing Bolt - 15mm Socket / Spanner
- Scuttle-Panel Securing Screws - Small Flat-head Screwdriver
- Wiper Motor Assembly Securing Bolts - Torx 30 Driver
- Wiper Motor Back-plate Bolts - Torx 20 Driver
- WHEELS
- Wheel nuts - 17mm Socket
- 108 Alloy wheel split-rim bolts - 8mm double hex drive
- ALLEN KEYS
- 5mm
- 6mm
- 7mm
- DRIVERS
- 8mm Double Hex
- Torx 20
- Torx 30
- SCREWDRIVERS
- Small Flat-head
- Medium Posidriv
- SPANNERS
- 15mm
- 16mm
- SOCKETS
- 15mm
- 17mm
- 36mm
