Staggered 19" front 20" rear with 255mm and 285mm Pilot Sport 4S
- Valor1
There are a number of reasons, performance and aesthetic, to run staggered wheels, that is, a smaller diameter front and larger diameter rear wheel. IMO the Z4 really needed a larger rear wheel to improve the aesthetics. The larger wheels also allow for an ideal tire fitment and a much larger tire patch in terms of both length and width. The wider tires really give the Z4 a more aggressive stance.
These 19" and 20" wheels are forged so these larger wheels and larger tires actually weigh less than the smaller OEM wheels and tires, improving acceleration and reducing unsprung weight which in turn improves handling and ride quality.
OEM 19” front wheels 27.778 lbs OEM Bridgestone Tire 24 pounds
19” rear wheels 29.247 lbs OEM Bridgestone Tire 27 pounds
Forged 19” front wheel 22.5 pounds Michelin Pilot Sport 4S 255 24 pounds
Forged 20” rear wheel 23.5 pounds Michelin Pilot Sport 4S 285 27 pounds
Total rotational mass savings is approximately 22 pounds.
Herb Adams, an engineer at Pontiac and race car engineer, wrote a well-respected book, Chassis Engineering, and the reduction of wheel rotational weight compared to static vehicle weight was estimated at a one to three ratio: For every one pound of wheel/tire rotation weight reduced it was the equivalent of reducing the vehicle’s static weight by three pounds. He proved his theories on the track where reduced rotating wheel/tire weights resulted in higher speeds and faster acceleration runs.
Applying that formula here my weight reduction of 22 pounds rotating mass is equivalent to reducing the Z4’s static weight by 66 pounds.
The larger tires also contribute to much improved handling and braking. As posted on another BMW forum by someone who fit lighter wheels and tires to his BMW besides better acceleration, "bumps were not transmitted as harshly, steering was more nimble, and steering response was more communicative."
Tire life should also be improved as there is less weight per cubic centimeter riding on the larger tires. Overall this set up gives the Z4 roughly 10 percent greater tire size than the Porsche Boxster Spider. My front tires are now as wide as the widest tires BMW fit to the rear of the Z4. Larger tire patch equals higher cornering capabilities and greater ability to brake harder without wheel lock up.
Looking forward to weighing the Z4 on my Longacre corner balancing scales ASAP.
- 20170814_185717.jpg (195.63 KiB) Viewed 2796 times
- SteveSmith
What tyre profiles?
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
- -banned-
...The larger tires also contribute to much improved handling and braking. Tire life should also be improved as there is less weight per cubic centimeter riding on the larger tires...improving acceleration ...
Are you saying you can able to beat laws of physics ?
Z4m coupe
- Smartbear
I would guess you've reduced your acceleration by raising the gearing of your car, those big wheels look to have a greater rolling radius than standard wheels. Tell us what profiles you're running?
e85 3.0si sold
- sunnydays
Wow OP that is a nice colour combination. Is that melbourne red and a beige interior? Manual too? Must not be many of those around in 35i form
- -banned-
I'm guessing rears 30 ,front 35 . That would noticeably reduce acceleration .
Z4m coupe
One HUGE disadvantage you have stated "less weight per cubic centimetre riding on the larger tires" With more rubber on the road their is as you correctly state less pressure on the tyre'. As a result you have poorer grip especially in wet or damp conditions where the tyres dynamics rely on the weight of the vehicle to push it down through the water film and contact the road.Valor1 wrote: ↑Tue Aug 15, 2017 4:18 am There are a number of reasons, performance and aesthetic, to run staggered wheels, that is, a smaller diameter front and larger diameter rear wheel. IMO the Z4 really needed a larger rear wheel to improve the aesthetics. The larger wheels also allow for an ideal tire fitment and a much larger tire patch in terms of both length and width. The wider tires really give the Z4 a more aggressive stance.
The larger tires also contribute to much improved handling and braking. Tire life should also be improved as there is less weight per cubic centimeter riding on the larger tires. Overall this set up gives the Z4 roughly 10 percent greater tire size than the Porsche Boxster Spider. (My front tires are now as wide as the widest tires BMW fit to the rear of the Z4.)
When tyres/wheels are selected by a manufacturer they are done by very skilled engineers, tyre specialists, and computers. They also use feedback from their race teams.
So, they probably know best, best left alone, safety before aesthetics.......
Oh, and make sure you tell your insurer as you have modified the cars handling......
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- metal licker
718 4.0 GTS Boxster in YELLOW
718 Guards Red Boxster .........Gone!
A35 AMG saloon .........Gone!
JCW ...........Gone !
E89 35i Msport VO ................Gone !
E89 23i SE DSB ................Gone !
Hello to Jason Isaacs
mcbutler wrote: ↑Tue Aug 15, 2017 9:08 amOne HUGE disadvantage you have stated "less weight per cubic centimetre riding on the larger tires" With more rubber on the road their is as you correctly state less pressure on the tyre'. As a result you have poorer grip especially in wet or damp conditions where the tyres dynamics rely on the weight of the vehicle to push it down through the water film and contact the road.Valor1 wrote: ↑Tue Aug 15, 2017 4:18 am There are a number of reasons, performance and aesthetic, to run staggered wheels, that is, a smaller diameter front and larger diameter rear wheel. IMO the Z4 really needed a larger rear wheel to improve the aesthetics. The larger wheels also allow for an ideal tire fitment and a much larger tire patch in terms of both length and width. The wider tires really give the Z4 a more aggressive stance.
https://www.driving.co.uk/car-clinic/wh ... -your-car/
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
looks like its on baloony front tyres and rubber band rears- overall rolling radius should be the same thus not sure how the acceleration has improved.... be suprised if a 20inch rim weighs less than an OEM 18" one :S
18 Z4s owned to date.
Current: 2.5i Titan silver
- R.E92
I don't think any race team feeds back information regarding optimal tyre size for a road car, two completely different applications.mcbutler wrote: ↑Tue Aug 15, 2017 9:08 am One HUGE disadvantage you have stated "less weight per cubic centimetre riding on the larger tires" With more rubber on the road their is as you correctly state less pressure on the tyre'. As a result you have poorer grip especially in wet or damp conditions where the tyres dynamics rely on the weight of the vehicle to push it down through the water film and contact the road.
Cars often have multiple tyre setups depending on spec. The 3 series for example has optional staggered wheels which come with the M Sport kit. The efficient dynamics cars come with smaller sizes again to reduce fuel consumption.
The tyres are the Z4 aren't selected solely for performance, they also take fuel consumption and road noise into consideration. Putting wider tyres on the Z4 will improve traction but will also increase fuel use and road noise into the cabin.
I can guarantee you that race teams feedback into road car development, why do you think they race to win? It showcases the manufacturers technologies and abilities, M series cars are very race orientated.R.E92 wrote: ↑Tue Aug 15, 2017 9:35 amI don't think any race team feeds back information regarding optimal tyre size for a road car, two completely different applications.mcbutler wrote: ↑Tue Aug 15, 2017 9:08 am One HUGE disadvantage you have stated "less weight per cubic centimetre riding on the larger tires" With more rubber on the road their is as you correctly state less pressure on the tyre'. As a result you have poorer grip especially in wet or damp conditions where the tyres dynamics rely on the weight of the vehicle to push it down through the water film and contact the road.
Yes cars often have staggered setups AS DESIGNED AND TESTED BY PROFESSIONALS.
All tyres are selected SOLELY for performance, you seem to think that it is only grip that is relative to tyre performance, it includes noise - economy - comfort - grip - braking wet/dry - cornering - acceleration.
Have a read of this website giving the views of professionals in the matter https://www.driving.co.uk/car-clinic/wh ... -your-car/
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- R.E92
If you actually read my post then you would see that I mentioned noise and fuel economy as factors, not just grip.mcbutler wrote: ↑Tue Aug 15, 2017 9:47 am I can guarantee you that race teams feedback into road car development, why do you think they race to win? It showcases the manufacturers technologies and abilities, M series cars are very race orientated.
My point is that identical cars come with multiple different tyre widths and profiles. There isn't one perfect setup.
It usually goes along the lines of the higher you spec a car, the wider the tyres. I'm perfectly aware that there are sacrifices for having wider tyres but faster cars have wider tyres for a reason.
I think the poverty spec Z4s actually come without staggered wheel setups. They have the same chassis and the same "race experts" overseeing the specification.
Valor1, have a read of THISValor1 wrote: ↑Tue Aug 15, 2017 4:18 am There are a number of reasons, performance and aesthetic, to run staggered wheels, that is, a smaller diameter front and larger diameter rear wheel. IMO the Z4 really needed a larger rear wheel to improve the aesthetics. The larger wheels also allow for an ideal tire fitment and a much larger tire patch in terms of both length and width.
- Valor1
Compared to the OEM Bridgestone Run Flat tires this set up, using the best all around tire on the market, the new Michelin Pilot Sport 4S (which replaces the Super Sport) this set up transforms the harsh riding 19" OEM set up into a much smoother and quiter ride. It is very similar to my SL600 in terms of ride comfort.R.E92 wrote: ↑Tue Aug 15, 2017 9:35 amI don't think any race team feeds back information regarding optimal tyre size for a road car, two completely different applications.mcbutler wrote: ↑Tue Aug 15, 2017 9:08 am One HUGE disadvantage you have stated "less weight per cubic centimetre riding on the larger tires" With more rubber on the road their is as you correctly state less pressure on the tyre'. As a result you have poorer grip especially in wet or damp conditions where the tyres dynamics rely on the weight of the vehicle to push it down through the water film and contact the road.
In addition, tire width is not the only factor in fuel economy.....as if fuel economy was the paramount concern for a sports car. Tire compounds are a significant factor in rolling resistance and these new Michelin tires are the latest tech on the market. I would gladly trade an mpg or two for this setup over the OEM set up.
As for how the Manufacturer equips their cars the fact is cost and marketing factor in. You can take the same BMW chassis and offer it as an economy car or an M tuned car and you'll note a dramatic difference in tires fit to the same basic vehicle architecture. The fact is COST is a huge player in any manufacturer's decision in how to equip a chassis for the market.
