Exhaust sound mod
Exhaust sound mod
On my 35is one thing I find very noticeable is that before I did the mod it would start up from cold with the flap open and be really rorty and then after 2/3 seconds as the flap closed it would quieten down and sound quite tame, also being a fairly steady driver, though not quite pipe and slippers yet !! I love to hear the extra growl you get pulling a high gear at low revs. One last thing I completely disagree with Maniac on the drone at motorway speeds because even as standard the flap would be fully open at speed, but I do appreciate the 35i/35is have different exhausts which may make a difference.
Exhaust sound mod
Is this flap fitted to all models of Zeee?
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
Exhaust sound mod
On the 6 cyl models only on the 3litre turbo's, on the newer 4cyl turbo's I'm not sure, but someone will confirm
- Smartbear
Exhaust sound mod
The 2 litre turbo engines have the exhaust flap as wellHillWalker wrote: ↑Wed Jul 26, 2017 6:09 pm On the 6 cyl models only on the 3litre turbo's, on the newer 4cyl turbo's I'm not sure, but someone will confirm
e85 3.0si sold
- Jasper ham
Exhaust sound mod
I tried this and did not find a lot of difference. I have now had the secondary cats removed and replaced with a straight through pipe and left the exhaust flap as it is. The car now burbles at tick over, but under heavy throttle it sounds really nice, not too loud and no drone at motorway speeds. In sport mode it accentuates the pops and bangs which is really entertaining.
BMW Z4 e89 35i white, black roof, 296 wheels emap to 390 BHP and running Vredestein Ultras. Second cat delete and straight through pipes.
- bob4333
Exhaust sound mod
Do you have to put your secondary cats back on come MOT time....?
- Jasper ham
Exhaust sound mod
No, it's a permanent mod. I did the same on my SLK55 which did sound amazing. The secondary cats keep down the emissions for countries with very tight regs, it will and has passed an MOT with them removed. The lambda sensors are only on the first cats on the downpipes so they also don't through up any errors once removed. The car is not noisy, but rumbles nicer and no drone. Would highly recommend.
- benv6
Exhaust sound mod
Any effects on the MPG though ?
Exhaust sound mod
This is incorrect, the flap will close at moderate motorway speeds to reduce drone. It is intended to open and close at different criteria such as revs speed engine temp and so on hence why it is ECU controlled.HillWalker wrote: ↑Wed Jul 26, 2017 5:42 pm On my 35is one thing I find very noticeable is that before I did the mod it would start up from cold with the flap open and be really rorty and then after 2/3 seconds as the flap closed it would quieten down and sound quite tame, also being a fairly steady driver, though not quite pipe and slippers yet !! I love to hear the extra growl you get pulling a high gear at low revs. One last thing I completely disagree with Maniac on the drone at motorway speeds because even as standard the flap would be fully open at speed, but I do appreciate the 35i/35is have different exhausts which may make a difference.
Exhaust sound mod
Maniac, first of all let me say that I personally don't get any drone at motorway speeds with the exhaust mod, but I do acknowledge your greater wisdom on all things Z4. So are we saying that if the flap is controlled by the ECU it affects the performance parameters more than just the little bit of extra noise on start up ? could it affect the torque figures due to reduced back pressure ? I certainly noticed a slight drop in fuel consumption figures after the mod, but put that down to me just giving it a few more beans to hear that sweet 6cyl sing.
As of this afternoon I've reconnected mine after 2years of running with it disconnected, as anyone else any thoughts on how it might affect driving characteristics other than the extra noise.
Exhaust sound mod
On almost all modern engines with free flowing well designed exhaust systems, the impact of changing the exhaust note will be negligible given where in the system the valve lies..its purely an emotion jerker..
- Jasper ham
Exhaust sound mod
No MPG still the same ...... poor with a lead foot lol
