Picked up a little gift
RickRob
Post by RickRob » Mon Jul 17, 2017 8:04 pm
buzyg wrote: Mon Jul 17, 2017 7:26 pm Yup that will probably be repairable. Easy enough to repair it your self with a kit from flea bay. Takes about twenty minutes, including reading the instructions. :wink:
This is the kit I have.
http://www.ebay.co.uk/itm/Tubeless-Tyre ... 41b2d43a25
Obviously you need a Compressor to re-inflate the tyre. :)
Unless it's a run flat, in which case your Screwed. :exitright:
How does that work?
I had assumed that professional puncture repairs were done from the inside with a mushroom-shaped piece of rubber, so that the pressure forced a good seal. Surely anything that gets inserted from the outside could pop out?
Smartbear
Post by Smartbear » Mon Jul 17, 2017 8:05 pm
Dam :thumbsdown:
e85 3.0si sold
Smartbear
Post by Smartbear » Mon Jul 17, 2017 8:08 pm
RickRob wrote: Mon Jul 17, 2017 8:04 pm
How does that work?
I've used those before (rats tails) never had a problem-it's pushed through the hole "doubled up" by the pick up tool.
The rats tails are rubber & coated in glue, excess length is trimmed off & they don't come out again :thumbsup:
e85 3.0si sold
RickRob
Post by RickRob » Mon Jul 17, 2017 8:18 pm
Smartbear wrote: Mon Jul 17, 2017 8:08 pm
How does that work?
Thanks Rob - that's my something learned for today!
eff1guy
Post by eff1guy » Mon Jul 17, 2017 8:29 pm
Get yourself a tire plugger kit off ebay. Uses the mushroom shaped rubber bung that is pushed in from the outside using the tool provided https://www.youtube.com/watch?v=-dfk0MXUuiM
Next Z landed ..... Z3 3.0i Sport Roadster
Z4 35iS ..... Gone to a new home
Online
buzyg
Post by buzyg » Mon Jul 17, 2017 9:03 pm
How does that work?
What Rob Said. :thumbsup:
I have only used the kit once. Worked well and I kept the tyre in normal used for around four months after, before purchasing a new pair.
ric19
Post by ric19 » Mon Jul 17, 2017 10:06 pm
If you read the advice from Bridgestone, RFT's are repairable as long as the tyre isn't driven whilst flat and meets the normal repair criteria. .I've had a rear repaired and had no issues at all.The only issue really is trying to convice the tyre repairer that you didn't drive it flat, so I just showed him the pump I keep in the boot and he accepted that
AndyW60
Post by AndyW60 » Mon Jul 17, 2017 10:54 pm
Thanks Ric will give that a try - only problem is now I've removed the bolt the tyre has deflated - my nearest tyre place isn't far though (about a mile) so hopefully they will do it. I do have a compressor but the hole is such that the tyre deflates immediately.
65 28i m sport
Smartbear
Post by Smartbear » Mon Jul 17, 2017 10:57 pm
AndyW60 wrote: Mon Jul 17, 2017 10:54 pm Thanks Ric will give that a try - only problem is now I've removed the bolt the tyre has deflated - my nearest tyre place isn't far though (about a mile) so hopefully they will do it. I do have a compressor but the hole is such that the tyre deflates immediately.
I think if you drive there on a flat tyre it could ruin it & they will refuse to repair :(
Have you another vehicle to take the wheel for repair?
e85 3.0si sold
AndyW60
Post by AndyW60 » Mon Jul 17, 2017 11:05 pm
I do Rob - think I might just bite the bullet and put a new one on though for piece of mind if nothing else - got two long motorway journeys in next few weeks. Hey ho!
Thanks everyone for your helpful comments - much appreciated :thumbsup:
Andy
65 28i m sport
Busterboo
Post by Busterboo » Tue Jul 18, 2017 12:12 am
buzyg wrote: Mon Jul 17, 2017 9:03 pm ...
So, you have a puncture and, for whatever reason, you have to replace the tyre.
When do you decide to replace the other tyre on the same axle?
(Assuming they're both in good general condition) if they've both had 6mm wear? 5mm? 4 ...
Or would you replace only the punctured one anyway?
Or always both?
Vidi, vici, veni
AndyW60
Post by AndyW60 » Tue Jul 18, 2017 11:45 am
Result..! Took wheel to local tyre chap and he said too good to replace and he could easily and safely fix it - £10 :thumbsup:
Called me a 'plank' for taking the offending bolt out though - said much easier for him if left in - lesson learned.
Thanks again for all helpful comments :thumbsup:
65 28i m sport
obewan
Post by obewan » Tue Jul 18, 2017 12:46 pm
ric19 wrote: Mon Jul 17, 2017 10:06 pm If you read the advice from Bridgestone, RFT's are repairable as long as the tyre isn't driven whilst flat and meets the normal repair criteria. .I've had a rear repaired and had no issues at all.The only issue really is trying to convice the tyre repairer that you didn't drive it flat, so I just showed him the pump I keep in the boot and he accepted that
My friendly local tyre fitter advised they know if run excessively as there will be small 'balls of rubber' running around inside the wheel when they take it off
As he helpfully pointed out on my wifes car recently :(
(Not run flat but under pressure)
I guess the problem is you need to take the tyre of the rim to prove it
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Online
buzyg
Post by buzyg » Tue Jul 18, 2017 5:49 pm
Busterboo wrote: Tue Jul 18, 2017 12:12 am
Or always both?
I would always try to match the tyre wear across the tyres. Last rear puncture I had was not repairable, so I replaced both, took the other tyre off and have it in the garage. Next time I get a none repairable puncture, I can hopefully pop it back on, rather than replacing both again. But that will depend on the wear.
Mr Tidy
Post by Mr Tidy » Tue Jul 18, 2017 6:02 pm
AndyW60 wrote: Tue Jul 18, 2017 11:45 amResult..! Took wheel to local tyre chap and he said too good to replace and he could easily and safely fix it - £10
Great news OP. :thumbsup:
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
