1.8i or 2.0i MSport 2014
Apart from the engine power is there anything else different about the two models?
I have head that the 1.8i is very easily chipped ie Spuperschips claim and extra 120bhp and 130nm.
My reason for the question is I am looking for a 2.0i but have only found a 1.8i with the spec I want
- hopz121
Go for the 1.8 mate, same engine I believe
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- 85genius
pretty sure everything is the same...
Check the 2 models on realoem if you want to look at any potential differences in specific parts
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
Thanks, I kind of thought they would be the same.
Having read a few reviews the concensious is that the non MSport is a much better ride?
- SteveSmith
Just ditch the run flats and fit normal tyres, the ride is a lot smoother.
I got the 28i but apparently an 18i and 20i will map to 260bhp. But the 28i will map to nearer 280-290bhp. Apparently they're all the same so no idea why the 28i produces more power when mapped.
I think the 28i has bigger brakes, if the 18i/20i has worse brakes than the 28i I'd definitely recommend upgrading them if you're planning on remapping.
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
In my experience fitting better pads makes a huge difference
Just hd a look at RealOEM and from what I can see the 1.8i and 2.0i share the same components.
The salesman, like so many, gave me some mubo jumbo re the difference in turbo re the engine siting the 1.8 has one, the 2.0 two and the 2.8 three
OnlineDeepseaskateboard
The 18i does not have dual zone climate as standard.
The four round controls on the dash look quite a bit different on the 18i
Have a look on auto trader and compare.
Interesting. You are well versed in the Z4 ways
I also notice you can't seem to get a 1.8i MSport either
OK, so lloks like I probable need to keep loking for 2.0i and above
- Smartbear
Evolve can get the 20i to this level & a decat downpipe can put another 20bhp on top... RobSteveSmith wrote: ↑Mon Jul 17, 2017 4:33 pm Just ditch the run flats and fit normal tyres, the ride is a lot smoother.
e85 3.0si sold
- Pastry
Or you could always go for a proper engine in the first place with the correct amount of cylindersSmartbear wrote: ↑Mon Jul 17, 2017 6:09 pmEvolve can get the 20i to this level & a decat downpipe can put another 20bhp on top...SteveSmith wrote: ↑Mon Jul 17, 2017 4:33 pm Just ditch the run flats and fit normal tyres, the ride is a lot smoother.
991 Carrera 2S
Now gone:
2010 Z4 23i Msport and a 3.0i
Now gone:
- Smartbear
Wow, you should ask him to point out all those turbos on the 28i, I'm surprised the bonnets able to closepetrolhead wrote: ↑Mon Jul 17, 2017 4:45 pm In my experience fitting better pads makes a huge difference
e85 3.0si sold
- Smartbear
Happy with my lot thanks, no cylinder envy herePastry wrote: ↑Mon Jul 17, 2017 7:36 pmOr you could always go for a proper engine in the first place with the correct amount of cylindersSmartbear wrote: ↑Mon Jul 17, 2017 6:09 pmEvolve can get the 20i to this level & a decat downpipe can put another 20bhp on top...SteveSmith wrote: ↑Mon Jul 17, 2017 4:33 pm Just ditch the run flats and fit normal tyres, the ride is a lot smoother.
e85 3.0si sold
Been there done that
- SteveSmith
But a 28i will map to more than that without the decat / dp and over 300bhp with it.Smartbear wrote: ↑Mon Jul 17, 2017 6:09 pmEvolve can get the 20i to this level & a decat downpipe can put another 20bhp on top...SteveSmith wrote: ↑Mon Jul 17, 2017 4:33 pm Just ditch the run flats and fit normal tyres, the ride is a lot smoother.
I personally wouldn't want to be driving my 28i with brakes worse than what it has.
If you can find a 28i then get one.
