E89 Tyre pressure monitoring
Hi All,
Latest question, yes searched the forums.
Does the E89 (mine is a 23i 2009) have the TPMS system that uses the sensors fitted inside the tyre or does it use the ABS based system?
If it uses the sensors in the tyre could you use tyre inflation form in the event of a flat tyre without destroying the sensor???
I don't use run-flats, ride is too harsh. Reinforced Michelin Pilot Sport 4 is lovely and sticky...
Thanks guys n gals....
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- ric19
ABS..tyre rotation monitoring
- metal licker
Think the tpms in tyre sensor was added with the the facelift in 2014 but I could be talking rubbish
718 4.0 GTS Boxster in YELLOW
718 Guards Red Boxster .........Gone!
A35 AMG saloon .........Gone!
JCW ...........Gone !
E89 35i Msport VO ................Gone !
E89 23i SE DSB ................Gone !
Hello to Jason Isaacs
I have been told that you can tell by the colour of the valve stem!
Apparently if the stem is black you have ABS based TPMS (apparently not very good)
If you have grey you have the actual in tyre pressure monitor!
Just out of interest do these sensors have a battery that requires replacement with the tyre?
If not how do they communicate their data to the car??
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Smartbear
My e89 is an lci facelift (Sep 13) and doesn't have the sensors in the wheels-I think they were introduced sometime in 14?metal licker wrote: ↑Thu Jul 06, 2017 4:30 pm Think the tpms in tyre sensor was added with the the facelift in 2014 but I could be talking rubbish
e85 3.0si sold
My 2012 MY Z4 has internal TPMS if you google TPMS there is a UK site that tells what version you have..
Cannot find this site, plenty of general info on TPMS, where to buy, how to fit, types os and which is best but nothing that specifies which type is fitted to which vehicle.
Do you have a link by any chance??
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Deepseaskateboard
https://www.nonda.co/products/zus-smart ... ty-monitor
Have a look at this clever gadget!
There is a cool video explaining how it works.
I may invest at some point!
https://www.tpmswarehouse.co.uk/index.p ... /tpmsmake/
It shows E89 2012 on all have TPMS based on in tyre unit..
I have ABS monitor system
Happy about that.
Happy about that.
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Smartbear
Not true, my Sep 13 car doesn't have the in wheel sensors?Pbondar wrote: ↑Fri Jul 07, 2017 11:51 am https://www.tpmswarehouse.co.uk/index.p ... /tpmsmake/
e85 3.0si sold
- ronk
If the rims have wobbly rubber valve stems it rotation - short stubby rigid stems its the TPMS system.
Well my 2012 with 296 wheels had internal and I replaced the wheels with new internal ones and they coded up fine.
Did have for a while some other wheels with no sensors and display showed tyre pressures greyed out
- dr_john
I have the TPMS system on my new 420, it's cool to see a display on the Idrive screen of all 4 tyre pressures, saves a lot of scrabbling about on hands and knees with a pressure gauge. Seems accurate as well.
Sapphire Black G29 2.0 MSport with Technology pack
