35is clutch drag.
35is clutch drag.
Bonjourno,
As we have normal clutches I'm wondering if there is any drag when we're sitting at lights etc, with the foot brake engaged. When I release the foot brake I can't detect any mechanical take up with the car starting to roll very smoothly, so I'm assuming there must be a degree of drag, however light it may be. I'm also assuming this drag, should there be any, will have been factored in with a certain tolerance to keep it light therefore keeping your foot on the brake rather than knocking it out of drive is perfectly ok and won't cause any discernible wear on the clutches any more than normal use. Or is it better to knock it out of drive at the lights and then re-engage? I've been tending to knock it out of drive as I'm very mechanically sympathetic but am I being over cautious?
Any thoughts appreciated.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- R.E92
35is clutch drag.
The DCT keeps the clutch packs disengaged at a standstill. It's only once you take the foot off the brake that it starts to engage.
35is clutch drag.
Thanks for that. It's a damn smooth engage then as I can't feel it, seems seamless to me.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- R.E92
35is clutch drag.
If you stomp on the accelerator pedal then you will feel it bite. Normally if ease away from a stop it's imperceptible.
- ronk
35is clutch drag.
Have you tried launch control yet?
A pal demonstrated it in his 330 xd (Company Car) and its a real shocker - it's without any mechanical sympathy to the system but a good party piece!
- jamesbond
35is clutch drag.
Have you tried it yet Ronk ??
Born in Yorkshire ended up in Essex .. 35is Mel red now sold
Own 2 big cats (F type & XE S supercharged) looking for a z4 Hobby Car
z4 3.0i 03 - Z4 3.0i 04 - Z4 3.0i 05 - Z4 3.0i 03 - Z3M (s54) 03 Man - Z4M 06 - Z4M 06 - Z4M 07 -
Z4 35is 2014
Z4 35is 2014
- ronk
35is clutch drag.
No !
It's a brutal load on components in my opinion and although it's been designed to cope with the load it does warn to allow 15mins of cooling time.
35is clutch drag.
It won't allow launch until it sees a pre-determined operating temperature. Personally I've no particular need to try it, you can launch hard enough without it should you have the inclination. Having said that I suppose having a 35is it would be a giggle to try it once just so you could experience it.
I always remember being at Ford Fair at Silverstone one year watching the 0-60 boys, a guy rolled up in a brand spanking new Mondeo ST220, he revved it to the limiter, dropped the clutch and the drive shaft snapping bang was met with raucuos totally unsympathetic applaud and jeering. An uncommon failureI'm sure but 0-60 etc, has never interested me so having said the above I probably won't try it....
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
35is clutch drag.
When it was demonstrated to me it was on the point if being scarey - one almighty single push and there seemed no way of being able to move forward out of the seat even if I'd wanted to!
A real party piece!
A real party piece!
35is clutch drag.
Have you seen Mr Plato testing the blue M roady in Switzerland just before it's launch? He bets his producer £5 he can't lean forward to pluck said fiver out of the dash under acceleration, Plato wins. The 35is, as you know, has at least, if not even harder, acceleration...
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
35is clutch drag.
I think that was the stunt Mr Shelby used to do in his Cobras .john-e89 wrote: ↑Sun May 07, 2017 10:21 pm Have you seen Mr Plato testing the blue M roady in Switzerland just before it's launch? He bets his producer £5 he can't lean forward to pluck said fiver out of the dash under acceleration, Plato wins. The 35is, as you know, has at least, if not even harder, acceleration...
35is clutch drag.
Yes he mentioned that in the clip..ronk wrote: ↑Sun May 07, 2017 10:48 pmI think that was the stunt Mr Shelby used to do in his Cobras .john-e89 wrote: ↑Sun May 07, 2017 10:21 pm Have you seen Mr Plato testing the blue M roady in Switzerland just before it's launch? He bets his producer £5 he can't lean forward to pluck said fiver out of the dash under acceleration, Plato wins. The 35is, as you know, has at least, if not even harder, acceleration...
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- ronk
35is clutch drag.
Now you mention itjohn-e89 wrote: ↑Sun May 07, 2017 10:50 pmYes he mentioned that in the clip..ronk wrote: ↑Sun May 07, 2017 10:48 pmI think that was the stunt Mr Shelby used to do in his Cobras .john-e89 wrote: ↑Sun May 07, 2017 10:21 pm Have you seen Mr Plato testing the blue M roady in Switzerland just before it's launch? He bets his producer £5 he can't lean forward to pluck said fiver out of the dash under acceleration, Plato wins. The 35is, as you know, has at least, if not even harder, acceleration...
