Anyone using 265/35 rear and 235/40 front tyres on 19's 326M?
- StanM
I'm thinking of getting new tyres and currently deciding between Micchelin PSS or PS4 S or the Vredestein Ultrac Satin but not sure which size to go for.
I've done some reading but it looks like not many E89 owners have tried the size I am after 265/35R19 rear and 235/40R19 front on a M Sport suspension.
I'm hoping to get a softer ride from the higher profile and bit more grip from the width.
My worries at the moment are will these rub either on the front or the rear and will they fit the standard 326M alloys which are 9Jx19 ET40 rear and 8Jx19 ET29 front.
Also if anyone can recommend a good Hunter garage anywhere near Loughton that would be great. Please don't say Protyre in Enfield as the mechanic there doesn't know how to fine tune and they don't seems to put weights in the car either.
2011 E89 sDrive23i M Sport Highline Edition, Alpine White, Coral Red Leather, 326M, Stubby
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
I have 295 on my rear and 235 on the front. No rubbing.
The 40 profile on the front may be an issue.
Z4 35is Valencia Orange. Custom Quad Exhausts Custom 400hp Remap.
- SteveSmith
I'm following this!
I personally think the car looks stupid with the profile on the tyres, standard tyres are 225/35 and 255/30 aren't they? I was looking at 235/35 and 265/35, I know this wiill probably make the rears slightly larger in terms of total rolling radius but not a lot??
28i M Sport - Alpine White / Canberra Beige, 19" M359’s, H&R’s / Eibachs, BMS Stage 1 - 271bhp, Front Splitter, CF Rear Lip, Alcantara Steering Wheel and Brembo 4 pots
- benv6
I am due for a change soon so I am closely following this thread as well
I was thinking of going 255/35 rear & 225/40 front ?
- gemeit
I am about to get some also for a new set of alloys 255 35 19 Rear & 225 35 19 Front for non sport suspension. As suggested by Mr Wilks thanks
- David-H
I am also watching with interest. I bought my 35i new last year and once I had driven it home (15 miles), I took off the 19-inch 326 wheels and RFT and replaced them with 19-inch 313 wheels with Eagle F1 rubber.
So, giving front 19/8.0 ET37 235/35 and rear 19/9.0 ET39 265/30 with no issues.
I was thinking that rather than have a set of virtually new OEM 326 wheels with OEM run flat tyres sitting in my garage, I could fit some nice non-runflats with deeper sidewalls and sell the OEM 19/225/35 & 19/255/30 tyres with 8mm tread all round to recoup a little of my outlay.
BMW Z4 3.0i auto ¦ Titanium Silver
107's : Drexler LSD
BMW M6 Gran Coupe ¦ Black Sapphire Metallic
DCT box with competition pack
Audi R8 4.2 Quattro¦ Grey metallic
6-speed manual
107's : Drexler LSD
6-speed manual
- StanM
Ok, seems like I'm not alone in this
Can someone with the right knowledge about rolling radius and aspect ratios explain if we can or can't go with the same 35 profile front and back and what are the pros and cons.
@SteveSmith, I agree the car looks like it can easily take a little bit taller and fatter tyres with no issue but I might be wrong.
My car is used as a GT cruiser for nice long Eurotrips (5K-6K miles) maybe once a year which is where I need the softer sidewalls and in the meantime as a weekend treat which might involve some spirited driving which is where I need more grip on the front.
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
- mr wilks
235 40 19 fronts on a 8j rim is a bit rash imo , go 235 35 or 225 40 but not 235 40
Rears i would be going 255 35 19 or if you prefer 265 30 but again 265 35 on a 9j rim is a step too far imo
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- benv6
The man has spoken
+1 I've just taken a photo of the post on my phone so I dont have to search for it when it's time to change. Thanks Mr W
Next Z landed ..... Z3 3.0i Sport Roadster
Z4 35iS ..... Gone to a new home
- StanM
Thanks Mr Wilks I've seen your comments on other posts but was thinking mine's different
I came across these two sites:
https://www.tyres-pneus-online.co.uk/ty ... dvice.html
http://www.etyres.co.uk/how-to-change-your-tyre-size/
and thought someone on here might have tried the maximum possible tyre width on 8 and 9 inch alloys just like my 326s and on the M Sport suspension and will be able to share some thoughts.
Looking at the second site it shows that 255/30-->265/30 change is just 6mm bigger in total diameter and in 255/30-->265/35 the difference is 32mm and it is a similar story for the fronts where 225/35-->235/35 is 7mm bigger and 225/35-->235/40 is 31mm
What will be the impact if I would go for the 265/35 rear and 235/35 front?
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
2004 E85 2.5i
2001 E46 320Ci
2000 E36/7 2.0i
- Wrs
This is the MPSS tyre setup I run with 326 alloys so keen to learn of any dangers too...What will be the impact if I would go for the 265/35 rear and 235/35 front?
Gone - Black Sapphire Z4 E89 35is
Gone - Midnight Blue Z4 E85 3.0si
- David-H
Hi Andy, not sure why you think that it's a step too far? 5mm nearer the suspension, 5mm sticking out further and filling out the wheel arch by 16mm seems not to bad to me as there's plenty of room on an E89's wheel arch? [Similar results on fronts going to 19/235/40]
- 19-265-35.jpg (91.7 KiB) Viewed 1599 times
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
- mr wilks
No other reason than a 245 or 255 width tyre is optimum fitment for a 9j rim , yes you can go 265 but to also increase the profile as well to 35 i think you are heading into a " balloony " look & cracking on it won't enhance performance or handling eitherDavid-H wrote: ↑Fri Apr 07, 2017 10:22 amHi Andy, not sure why you think that it's a step too far? 5mm nearer the suspension, 5mm sticking out further and filling out the wheel arch by 16mm seems not to bad to me as there's plenty of room on an E89's wheel arch? [Similar results on fronts going to 19/235/40]
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
