Modded 35is, Rolling Road Results
- jleckenby
Hey all,
Following on from my thread on mods (viewtopic.php?f=23&t=95078), I have been to a rolling road today to see what she's making.
So yeah, pretty pleased with that
Z4 35is, 438bhp
Cobb Stage 2 (Aggressive), VRSF Catless Downpipes, BMS DCI, NGK Iridium Spark Plugs, Eibach Springs
OnlineLynchy
438 BHP! Wow !
- flimper
nice
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
That will be quick
Proper sleeper
Proper sleeper
- jabber
Am I reading that graph correctly loosing 137 bhp through drive train?
Z less again
- jleckenby
Yep, thats pretty normal though I think!
Z4 35is, 438bhp
- Chris_D
295 @ the wheels is the figure that counts.
How heavy are you? If >=100Kg then knock off 50 bhp at the wheels
- jleckenby
Hehe, safely under 100 for now!
Z4 35is, 438bhp
- R.E92
There's something wrong with the dyno if you are making 438 at the crank but only 295 at the wheels. That's a 30% drivetrain loss!
Did they do something stupid like calculate the power using the manual gear ratios not the DCT?
The crank figure is about right though. I would expect 440bhp from a stage 2 car.
AFAIK BHP is a measure of power at the output of the engine, WHP should be used for the wheel figure so there's another thing not quite adding up with the dyno chart.
- Rockford
Thought the same, whp seems way down on what I'd expect. Nice headline figure though, must really get a move on.
2019 BMW M40i First Edition Frozen Orange
2014 BMW M4 DCT Yas Marina Blue
Previous Zeds:
2010 BMW Z4 35i DCT (Evolve: 360BHP)
2009 BMW Z4 35i DCT
2003 BMW Z4 3.0i manual
Previous Zeds:
2009 BMW Z4 35i DCT
- jleckenby
It was done using a coastdown run, did it a few times. Does seem on the high side, but with the drivetrain drag measured, headline should be pretty accurate. Worth noting I did a stock run on same dyno and got 340bhp.
Z4 35is, 438bhp
- R.E92
I'm a little confused how they managed to get the WHP figure so wrong though. Doing a little reading I have found a few topics across the web that state it's normal for Maha dynos to over-report drivetrain losses as they also factor in the losses at the roller into the calculation.
Your wheel horsepower is more like 380. 13% loss is typical for our cars from what I've seen at other sources.
If you have your COBB to hand you can do a few logs and enter them into VirtualDyno. I think you should get a figure similar to 380 (VirtualDyno measure wheel horsepower) which would give some faith in the dyno.
- R.E92
Very good result though. You will soon get accustomed to the power.
Whenever I go back to the 302bhp stock map the car feels pathetic
- jleckenby
Youre probably right, its going to be factoring in more than just drivetrain. Overall it should be accurate for the headline figure though, thats whats important.
380 at the wheels, lovely
Z4 35is, 438bhp
- Kingfisher
I used to get racing car engines dynoed frequently ... given that all race car engineers seem to hate each other I think they used to tell you what you wanted to hear ... they always slagged off the opposition when it came to producing bhp and as for those charts ... I often used to wonder about them! ...
Dec 2014 ... E89 35is sDrive M DCT ... Red ...
