How to reset front brake service E89
Hi all when I start my bme E89 2.3 S Drive it now shows front brake pad 800 Miles but my pads are like new anyway I tried reseting it if I'm doing this correctly put key in dash press start button but don't start the engine I hold trip button 5-10 seconds which shows yellow triangle service it goes to front brake service I hold the BC button on stalk to reset I see the clock going around but it still ends up showering 800 miles lol anybody know if I can reset this thanks
Hi all as my front brake pad service light is on the count down showing 700 miles at mom every time I start the car I been told the car calculate the way you brake and they like you to change pads early so not sure if I need to just hold on and change pads and sensors or just buy new sensors not sure what's best to do any advice be great
- Jasper ham
I've just had this with my 35i, front pads fine but the service light would not reset. My local Indy checked it and it was a faulty sensor, I think the sensor is around £16 and about 30mins labour.
BMW Z4 e89 35i white, black roof, 296 wheels emap to 390 BHP and running Vredestein Ultras. Second cat delete and straight through pipes.
Chances are the pads have been changed and not the sensor.
Reset requires a diag tool on E89..
- Nictrix
Is this definately right?
I have just changed the front disks, pads and sensor and rear pads and sensor on my X6 and reset them via the dash.
It is not reset through the idrive or BC button but through the mileage trip reset button which brings up another service menu that can reset the service intervals.
The button is pressed and held in until an exclamation mark appears on the dash, then one of the serviceable icons appears, like front brakes-rear brakes-brake fluid-oil change-MOT, take your finger off the button and then press it again until the item you want to change appears on the dash. When it is on the dash, press and hold the button again until "reset" appears on the screen, press and hold the button again until the mileage changes to just dashes, it will then show the new mileage.
I have not tried this in the Z but it would be worth a try.
You know im not 100% sure,i thought it was.
We always use the diag tool on the E89....
