Tyre pressures on 19"
Hi all, hear alot about the alloys cracking! Im on bridgestone potenza. I think runflats. Whats best pressures to run to avoid this cracking?
Cheers all
Cheers all
- Nictrix
You are about to open up a can of worms.
I doubt you will get a proper answer to this question.
The only thing I would say to avoid cracking 19s with runflats is avoid potholes.
Same could probably be said for 19s with non runflats too though.
Sorry no worms please!
- jimbo1958
Agreed.Nictrix wrote:You are about to open up a can of worms.
Replaced my 19" RFT's to MPSS within a week of ownership and touch wood, no cracks even after hitting a few potholes over the years.
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
- Nictrix
Michelin Pilot Super SportsMrBrucelee1972 wrote:MPSS???
By all accounts, your chances of cracked wheels seem quite high.MrBrucelee1972 wrote:Hi all, hear alot about the alloys cracking! Im on bridgestone potenza. I think runflats. Whats best pressures to run to avoid this cracking?
Cheers all
Have you checked to see if they're cracked already?
Vidi, vici, veni
- benv6
Go non-RFT as soon as you can, you will get a much better handling too
- Silverzedtom
Go to a track with the intention of wearing them down on silky smooth tarmac where they won't be taking hits.
Get some decent non rft's on, by this time you've got the track bug and will want to return. You will see on track how much better the cars handling and it will all be justified!
E85 2.5si
F55 Cooper S
F55 Cooper S
The 'theory' is that low-profile runflats + potholes cause BMW OE 19" alloys to crack.MrBrucelee1972 wrote:Hi all, hear alot about the alloys cracking! Im on bridgestone potenza. I think runflats. Whats best pressures to run to avoid this cracking?
Cheers all
Some argue that, because runflats give a hard ride, owners under-inflate them and it's this that contributes to the problem.
The cure-all, but ridiculously expensive solution, is obvious, of course. Don't use OE 19" wheels. However, to 'abandon your runflats' seems a viable compromise, doesn't it? They are, after all, crap tyres.
Vidi, vici, veni
