The warranty period is considered reasonable in the eyes of the law. Otherwise, i'd buy an old E30 and take is back to moan about the rust!ronk wrote:However goods do have to be fit for purpose and exhibit a quality that could be reasonably expected?Zed Five wrote:There is, but there is no obligation. My point is, noone can moan once out of warranty.
Dreaded Run Flats / 326M alloys
- Zed Five
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
- ronk
But that wouldn't be reasonable to expect an old car with maybe dubious history to be free of rust?
It seems to me that cracked wheel claims are being rejected based on some very suspect hypothesis and certainly not based on any engineering or metallurgical analysis.
More than sluggish response..apologies...'twas slow puncture on rear left. Both rears need replacing anyway so that will be circa £450 but on bright side this I'm hoping rules out any more drastic problems...
P.S roof down weather has arrived folks
- IMG_6278.JPG (142.18 KiB) Viewed 831 times
- ronk
My guess was right!
I wish I could pick the lottery numbers as well
Hi does anyone know if replacing awful Bridgestone rft's with the Michelin run flats which have very positive reviews effects the idrive the pressure monitor? In other words will it still work normally? Can't see any reference or threads mentioning it..
My TPMS did nothing when this happened
tyre was completely flat, had about 6mm left, as did the opposite wheel!
Good riddance RFTs....
- Nictrix
Was it set properly?willgill wrote:My TPMS did nothing when this happened
According to Ocean BMW the last time the RFTs were replaced at Sytner (not by me) the TPS was calibrated.
I'm not sure if the e89's TPS is based on rotational reduction or internal pressure, either way it should have pinged up regardless, the tyres were totally flat.
- ronk
My previous Dec 2010 was by rotation the Sept 2016 has a tpms system - I don't know when tpms was introduced.
Apart from the dealer calibration, were you also manually resetting the TPMS every time you fill your tyres? If not the tyres won't be set to the correct pressure.willgill wrote:According to Ocean BMW the last time the RFTs were replaced at Sytner (not by me) the TPS was calibrated.
2013 E89 35iS Mineral White
19" 326M | heated seats & wheel | pro nav & hifi | stubby
Gone: 2010 E89 23i Space Grey
Never touched the tyres aside from a visual inspection for tread, probably done less than 1000 miles since I bought the car certainly never added any air to them. I can't think of any car I've owned that I've had to constantly add air too, what are you doing to warrant that?extrablatt wrote:Apart from the dealer calibration, were you also manually resetting the TPMS every time you fill your tyres? If not the tyres won't be set to the correct pressure.willgill wrote:According to Ocean BMW the last time the RFTs were replaced at Sytner (not by me) the TPS was calibrated.
- mr wilks
So in your 1000 miles you never once checked all 4 tyre pressures other than visuallywillgill wrote:Never touched the tyres aside from a visual inspection for tread, probably done less than 1000 miles since I bought the car certainly never added any air to them. I can't think of any car I've owned that I've had to constantly add air too, what are you doing to warrant that?extrablatt wrote:Apart from the dealer calibration, were you also manually resetting the TPMS every time you fill your tyres? If not the tyres won't be set to the correct pressure.willgill wrote:According to Ocean BMW the last time the RFTs were replaced at Sytner (not by me) the TPS was calibrated.
There is so little sidewall its very easy to have 3 tyres correctly pressured & 1 running say 15Psi ?
As i understand it you can reset the TPMS with 4 differing pressures & only if one of those 4 alters will it ping so you could well have covered your 1000miles whilst the tyre was technically running flat hence the outcome you pictured
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Smartbear
My Sep 13 car is also rotational & not pressure.ronk wrote:My previous Dec 2010 was by rotation the Sept 2016 has a tpms system - I don't know when tpms was introduced.
e85 3.0si sold
In the past I've probably knocked up 2k+ a week and aside from visual review I'd no more think about checking the tyre pressures than flying to the moon, granted most of the cars I owned had independent pressure monitors on them which should have pinged up any issues, but still it's not something I've done since the heady days of driving to cornwall as a young lad.mr wilks wrote:So in your 1000 miles you never once checked all 4 tyre pressures other than visuallywillgill wrote:Never touched the tyres aside from a visual inspection for tread, probably done less than 1000 miles since I bought the car certainly never added any air to them. I can't think of any car I've owned that I've had to constantly add air too, what are you doing to warrant that?extrablatt wrote:
Onto the tpms discussion, when you reset it each sensor has its own value recorded and a drop of pressure (or rotation if you have a newer system) would ping an alarm for any and all tyres independently. So it will record one flat tyre after another until you replace them or they all go flat. It's not a one size fails all setup
I ordered four replacement sensors because the garage the car got stranded at didnt have an inpa/sss setup to read each value (they were just a hunter specialist)
End of the day I'm glad to see the back of the RFTs, utter garbage tyres. However, maybe I'll change my dependence on technology in the future.
- mr wilks
I understand what you say above willgill but its possible (prior to your purchase ) the car had its TPMS reset when 3 tyres were ok & 1 wasn't Therefore no triggering would have occurred even though one could well have been running on low pressure for the 1000miles
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
