Forgive the newbie question. How can I lower the high beams?
Not only are the low beams too low, but the high beams are much too high.
I've found, I believe, the low beam adjusters, but not the high.
High beams much too high
Vidi, vici, veni
- Smartbear
Hi, the under bonnet adjusters work for both high & low beams I think-they are the white plastic hex heads behind the lights, one is up/down, the other left/right.
e85 3.0si sold
No way to adjust high beams, just have to accept that half the light is above the horizon.
I'm assuming the dipper is just a shutter that cuts off half the light.
The adjuster just raises or lower the body of the lamp?
Good in tunnels I suppose.
E89 is always Xenon. I thought high beams were just that.. high. I.e. They illuminate everything.
I find my high beam, well 'high' as they illuminate everything.
2009 (59) Z4 E89 3.0i Sdrive in deep sea blue, white extended leather, I-drive, folding mirrors. Suzuki GSX 1300R Hayabusa
Larger diameter rear tires.....
