Tire wear
Tire wear
Wow!
That's some serious uneven wear. Get your car in for a wheel alignment check asap.
E89 23i M Sport, Saphire Black, Canberra Beige Leather.
Mods: De-badged, blue callipers, gloss black LCI's and roll over hoops, black performance grills, stubby aerial, rear carbon diffuser, gunmetal powdercoated alloys, custom stainless cat back exhaust.
- Smartbear
Tire wear
That's not the camber, it's poor toe in/out that causes that-get your wheels aligned asap
e85 3.0si sold
- Smartbear
Tire wear
And perhaps check for tyre wear over the full width a little more often as well
e85 3.0si sold
Tire wear
Would under pressure not wear on both outside edges?Maniac wrote:Run flats? If yes the possibly under pressure.
Tire wear
If these are rears, my 19" are 2,9 bar, circa 42psiTimdon wrote:Yes run flats what pressure should they be ?,the tire centre put them at 32 psi when I purchased them
Run flats have very stiff sidewalls, when at a low pressure the cars weight sits on the sidewalls rather than load through the tyre. This causes rapid wear due to high rear camber from factory.
I too suffered this early on and as a result I'm fastidious about pressures and haven't had an issue since.
That plus a switch to non run flats.
Tire wear
That's got to be tracking, mine wear even, not like when I first had the car re; the fronts.
The rears are toe in so should wear outside. So could be too much toe out and/or camber, which is set by rotating the rear mount bolt on a cam.
Onlineronk
Tire wear
My previous Car exhibited similar wear - the dealer said it was fairly typical.
Not sure if I believe him now - one thing is for certain I'll be keeping an eye on the new car!
