Full Oil Change on Friday, which oil should I use?
- DinosaurEyes
E89 35is 70k miles
Last time someone brought this up, the general consensus seemed to be Castrol Edge 5w30 was the best, right? Is this still the case or are there any others I should consider using instead, and why?
- DinosaurEyes
Is Titanium just new branding, same oil?
- mr wilks
Oil as tyres is subjective & will divide opinion
My preference is for Millers CFS or Nano
Yours being a twin turbo heading for 400bhp performance id want something up to the job
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
last month I got oil and ecp was trying to tell me the castrol magnatec was cheaper and most modern cars now use it. I always thought magnatec was for diesels don't know why. Anyway as I've always used castrol edge in all my bmw's so I got that instead. Since then seen a few mention they always use magnatec
magnatec was £30 and edge was £37
if you use one of the codes can get edge for £32 at ecp
- alane29
Its personal choice i guess ,but i use Shell helix 5 -30 fully synthethic
2007 E86 M Coupe
2005 E85 2.5SE
2005 E85 2.5SE
- DinosaurEyes
The specs on Castrol Edge are suggesting the CASTROL EDGE 0W-30 for the N54. That's ok right?
mr wilks, is this the Millers one you mean? http://www.opieoils.co.uk/pv-98942-mill ... mentNotes=
- mr wilks
Yes mate or Comp Fully Synth CFS is equally as good & a bit less ££
I buy Millers because I think its top notch quality oil & not for the supposed enhanced performance from it
When I put it in the ZM it was particularly for its qualities of lowering friction therefore keeping things as cool as poss
There are many reviews online to read & can't ever remember any negative ones . All make interesting reading
https://www.tegiwaimports.com/blog/445/
http://www.fastcar.co.uk/tuning/millers-nanodrive-test/
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Marlon
Just make sure its fully synthetic and you can't go wrong
Gone: 3.0si 2008 E85
911 997 Carrera S
- mr wilks
For the mostpart I would agree but M cars were developing problems that pointed to crappy oil or excess heat or bothMarlon wrote:Just make sure its fully synthetic and you can't go wrong
The turbo cars also develop much heat & any way of keeping that down has to be a advantage , oil being the coolant + lubricant for the engine is probably more important imo than choice of fuel
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- patriot66
Castrol Edge for me. Never had any issues with Castrol oil in any of my cars over the last 33 years. Never used anything else.
I use Comma Syner Z 5w-30 A Fully synthetic oil .You can check out www.commaoil.com enter your reg and it will give you the recommendation and details
Panther Kallista 2.8
S Drive 3.0i E89 2009 Space Grey Coral red Int 18" 295 wheels
- DinosaurEyes
Thanks for all the suggestions folks! I've decided to give the Millers a try and ordered that. Will be interesting to see if I can tell the difference!
