Dashcam
- techathy
Dashcam
had something similar to this stolen from my car broke a few bits of trim as well... also introduced a rattle under some conditions which I'm yet to track down
Current: '09 Lotus Evora Launch Edition
Previous: '13 BMW 120dx, '15 BMW z4 35iS
Dashcam
I'm not sure I would have mounted the Mini 0806 driver's side but each to their own, either way looking at the screen it appears to give a good angle.
How have you found the Mini 0806? They were removed from CarCameraShop due to reliability issues and many people have commended online that they have only lasted 12 months or so?
Has anyone hardwired theirs to an E89? Either with a power magic pro or other means and if so have you got any drive low voltage warnings?
Currently waiting for Blackvue to announce an update on the DR600 range before I decide. The shape of the Blackvue to me is its biggest selling point being cylindrical, black and no lcd screen.
Nice to see other examples though.
Instagram @Zed4_M40i
2020 to 2021 - BMW G29 Z4 M40i
2017 to 2020 - BMW F21 M140i
2016 to 2017 - BMW E89 Z4 35i S
2015 to 2016 - BMW F20 M135i
2013 to 2015 - BMW E82 123d M Sport Coupe
2007 to 2011 - BMW E85 Z4 2.5i Sport
- TitanTim
Dashcam
I had the Mini 0806 in my M135i for over 12 months and just taken it out as traded the car in. Its likely it will be thrown in the bin when I take delivery of the new car and will look at an alternative cam. I've found the Mini to be unreliable, the mounting bracket is poor with an iffy connection. I've found the unit to run extremely hot so much so you can't hold it in your hand at times. Mine has frozen on occasions and I've been unable to power it off so had to disconnect it from its mount and wait for the battery to run down before I can use it again. Reading some reviews its a common problen. I like the size of the cam but thats about it.
Tim.
Tim.
- techathy
Dashcam
I'm sure you could fit them in the trim. The issue I see is overheating & getting access to the SD cards if I want to.
I have actually ordered a Mobius though.
- David-H
Dashcam
Had my Blackvue DR650GW-1CH put just to the passenger side of my rear view mirror with the hard-wire kit for use when parkred:
- blackvue1.jpg (48.7 KiB) Viewed 863 times
- blackvue2.jpg (60.4 KiB) Viewed 863 times
BMW Z4 3.0i auto ¦ Titanium Silver
107's : Drexler LSD
BMW M6 Gran Coupe ¦ Black Sapphire Metallic
DCT box with competition pack
Audi R8 4.2 Quattro¦ Grey metallic
6-speed manual
107's : Drexler LSD
6-speed manual
Dashcam
This is the exact setup I am looking at. How have you found the blackvue? Did you use the Power Magic Pro? Do you ever get any low voltage warnings?DLH wrote:Had my Blackvue DR650GW-1CH put just to the passenger side of my rear view mirror with the hard-wire kit for use when parkred:
Thanks.
- David-H
Dashcam
It is connected using the Power Magic Pro set at 11.8v and,as yet, no low voltage warnings. The only issues with warnings have been related to motion in the parking mode where I had the sensitivity set too high.Raesy wrote:This is the exact setup I am looking at. How have you found the blackvue? Did you use the Power Magic Pro? Do you ever get any low voltage warnings?DLH wrote:Had my Blackvue DR650GW-1CH put just to the passenger side of my rear view mirror with the hard-wire kit for use when parkred:
Thanks.
I have nothing to compare the blackvue to, as it's my first dash am, but I do like it and it works well over WiFi using Blackvue Cloud services so I'm pleased with it.
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
- obewan
Dashcam
Anyone know if this is any good?
Particularly interested in the OBD hardwire kit - thought it may stop hours of fun taking courtesy light apart/searching for the correct power outlet (and blowing fuses)
Thoughts and comments appreciated
http://www.ebay.co.uk/itm/UK-EYOYO-0806 ... SwpRRWp5cM
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
Honda CB500F.
Dashcam
This is another re-brand of the E-PRANCE Mini range. Unreliable sadly, as mentioned above...obewan wrote:Anyone know if this is any good?
Dashcam
Thanks DLH, just the answer I was looking for. Easy to fit the Power Magic Pro I presume?DLH wrote:It is connected using the Power Magic Pro set at 11.8v and,as yet, no low voltage warnings. The only issues with warnings have been related to motion in the parking mode where I had the sensitivity set too high.Raesy wrote:This is the exact setup I am looking at. How have you found the blackvue? Did you use the Power Magic Pro? Do you ever get any low voltage warnings?DLH wrote:Had my Blackvue DR650GW-1CH put just to the passenger side of my rear view mirror with the hard-wire kit for use when parkred:
Thanks.
- David-H
Dashcam
It took a total of 2 hours to fit the DR650GW + Power Magic Pro + hardwiring an Aguri Skyway unit fitted on the dash. The Auto-Electrical shop that did it seemed to think that it was straightforward enough.Raesy wrote:Thanks DLH, just the answer I was looking for. Easy to fit the Power Magic Pro I presume?DLH wrote:It is connected using the Power Magic Pro set at 11.8v and,as yet, no low voltage warnings. The only issues with warnings have been related to motion in the parking mode where I had the sensitivity set too high.Raesy wrote:
Thanks.
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
Dashcam
Thank you :thumbs: Blackvue purchased and should be here tomorrow!DLH wrote:It took a total of 2 hours to fit the DR650GW + Power Magic Pro + hardwiring an Aguri Skyway unit fitted on the dash. The Auto-Electrical shop that did it seemed to think that it was straightforward enough.Raesy wrote:Thanks DLH, just the answer I was looking for. Easy to fit the Power Magic Pro I presume?DLH wrote: It is connected using the Power Magic Pro set at 11.8v and,as yet, no low voltage warnings. The only issues with warnings have been related to motion in the parking mode where I had the sensitivity set too high.
- David-H
Dashcam
Raesy wrote:Thank you :thumbs: Blackvue purchased and should be here tomorrow!DLH wrote:It took a total of 2 hours to fit the DR650GW + Power Magic Pro + hardwiring an Aguri Skyway unit fitted on the dash. The Auto-Electrical shop that did it seemed to think that it was straightforward enough.Raesy wrote:
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
- London_Gains
Dashcam
Looks great - how much did the unit and the fitting ser you back if you don't mind me asking?DLH wrote:It took a total of 2 hours to fit the DR650GW + Power Magic Pro + hardwiring an Aguri Skyway unit fitted on the dash. The Auto-Electrical shop that did it seemed to think that it was straightforward enough.Raesy wrote:Thanks DLH, just the answer I was looking for. Easy to fit the Power Magic Pro I presume?DLH wrote: It is connected using the Power Magic Pro set at 11.8v and,as yet, no low voltage warnings. The only issues with warnings have been related to motion in the parking mode where I had the sensitivity set too high.
To Do: 19" Staggered CSL Rims
DONEConti Sport Contact 6 Tyres: DONE
KW V1 Coilovers DONE
LaminX Headlights and TailightsDONE
Quad Pipe Conversion - Eissenmann Race Quad Ordered [23/05/2016 - Being built in Germany]
