Fitting non-RFTs - need new TPMS valves?
Hi,
Quick newbie question - if I swap my tyres for non runflats, will I need to do anything about the tyre pressure sensors or can I just pick any tyre that fits and get it fitted?
Thanks,
Av
Thanks,
Av
- Ducklakeview
Straight swap.
Mike
Mike
much obliged!
Avallon wrote:Hi,
Thanks,
Av
Is this on an E85/E85 or E89?
I believe they are needed on the E89 but not older models
- David-H
If you're just changing from RFTs to non-RFTs on the same rims then just leave the valves in and then do a reset when the new tyres are fitted and pressurised. If you're also changing the rims, then you'll need to fit valves with sensors.Avallon wrote:Hi,
Thanks,
Av
BMW Z4 3.0i auto ¦ Titanium Silver
107's : Drexler LSD
BMW M6 Gran Coupe ¦ Black Sapphire Metallic
DCT box with competition pack
Audi R8 4.2 Quattro¦ Grey metallic
6-speed manual
107's : Drexler LSD
6-speed manual
- Nictrix
This depends on what year the car is.DLH wrote:If you're just changing from RFTs to non-RFTs on the same rims then just leave the valves in and then do a reset when the new tyres are fitted and pressurised. If you're also changing the rims, then you'll need to fit valves with sensors.Avallon wrote:Hi,
Thanks,
Av
- David-H
Being as the question is posted in the E89 discussion thread then isn't it reasonable to assume that the car is an E89 and no older than 2009? My answer is based on that assumption and that E89 cars from 2009 onwards use 433MHz TPMS sensors together with my own recent experience in fitting non-RFTs.Nictrix wrote:This depends on what year the car is.DLH wrote:If you're just changing from RFTs to non-RFTs on the same rims then just leave the valves in and then do a reset when the new tyres are fitted and pressurised. If you're also changing the rims, then you'll need to fit valves with sensors.Avallon wrote:Hi,
Thanks,
Av
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
- Nictrix
There are 2 different TPMS systems on E89s depending on the year of manufacture.DLH wrote:Being as the question is posted in the E89 discussion thread then isn't it reasonable to assume that the car is an E89 and no older than 2009? My answer is based on that assumption and that E89 cars from 2009 onwards use 433MHz TPMS sensors together with my own recent experience in fitting non-RFTs.Nictrix wrote:This depends on what year the car is.DLH wrote: If you're just changing from RFTs to non-RFTs on the same rims then just leave the valves in and then do a reset when the new tyres are fitted and pressurised. If you're also changing the rims, then you'll need to fit valves with sensors.
The earlier E89s do not need special valves in the wheels, the later ones ( after 2014?) do.
- David-H
Checked to see what TPMS sensor works on a 2010 E89 and it appears that the HUF model is the same as for my 2016 E89?
- TPMS-sensor.jpg (57.98 KiB) Viewed 2179 times
107's : Drexler LSD
6-speed manual
107's : Drexler LSD
6-speed manual
- Nictrix
Im sure that info is wrong.
Ours have normal valves.
Experts will be here soon to correct one of us
Our 20i was built in February 2014 and just uses the ABS to detect deflation in any tyre, hence the need to reset it periodically
I believe later models have a more sophisticated system requiring the special TPMS (sensor) valves as with our Evoque.
2014 Z4 2.0. (driven by her in doors cos she thinks she looks pretty in it).
Range Rover Evoque (toss up between one of these and an X4)
Alfa Giulia Quadrifoglia
- KERMIT1970
E89 after April 2014 have the new setups in the wheels. Pre April 2014 have normal v/v's with tpms built into Hub/abs this is uk build were talking about
Cars: 2016 M4 vert YMB & X3m Comp. E30 325i Sport. Z3M
Gone
: 2014 z4 35is melbourne red & black leather
: 335d M sport Coupe Black with red leather
: z4 Coupe 3.0 si Red with Black Leather 18" CSL`s
: z3 2.2 sport
Gone
: z3 2.2 sport
- techathy
Before 3/2014 you’re only likely to see active TPMS in cars supplied for very hot climates where RFT tyres overheating when properly inflated was a concern. The pre-03/2014 system is an older design and uses a different model of HUF sensor to the post-03/2014 cars. All after 03/2014 all E89s use an in-wheel sensor and while the packaging for both sensors is the same the systems are NOT cross compatible.
Oh, it is worth noting that some UK cars randomly get supplied with the hot-climate kit which on the E89 includes active TPMS sensors.
Current: '09 Lotus Evora Launch Edition
Previous: '13 BMW 120dx, '15 BMW z4 35iS
My car is a 64 plate - so does that mean I need new sensors if I move away from RFTs?
- techathy
Probably will need TPMS sensors but if you're just swapping tyres on your existing wheels there's no need to change the sensors.
