Auto or manual
- GuidoK
Re: Auto or manual
Perhaps we have a different view on quickly.
One should think there would be a reason why automatics arent used in racecars.
I mean even F1 has an oldfashiond shifterdrum system (so manual sequential) like has been used for decades on motorcycles.
Just like rallycars.
No slushboxes there I can tell you.
Re: Auto or manual
Perhaps we do.GuidoK wrote:Perhaps we have a different view on quickly.
None of my old manual cars have needed to go down to 3rd from 6th in order to overtake.
Mainly because if I did that the engine would explode - 3rd isn't good when coming down from cruising at 90 in 6th
- GuidoK
Re: Auto or manual
Well we definately have a different view on overtaking.
I'm probably the one closing really fast in your rear view mirror....
Re: Auto or manual
Doubt itGuidoK wrote:Well we definately have a different view on overtaking.
- GuidoK
Re: Auto or manual
Then why do you say your engine will explode when shifting back to 3rd?
At? 90mph?
My 3rd goes to 96.
That's something you'd know if your closing really fast in rear view mirrors of people who think they go fast
At? 90mph?
My 3rd goes to 96.
- ronk
Re: Auto or manual
It would seem to me that the entire army is marching out of step except one man !
- jimmybell
Re: Auto or manual
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
- GuidoK
Re: Auto or manual
Too bad none of you want to discuss all the technical workings and mechanics of an automatic for which I gave so many hints.ronk wrote:It would seem to me that the entire army is marching out of step except one man !
I guess that takes another level of understanding
Re: Auto or manual
I think we should have a project marmite typecollection to see Guido change down to 3Rd from 90 in 6th in order to accelerate..
I'd love to see what happens .
- mr.tourette
Re: Auto or manual
lets be honest here, there is plenty of discussion but it seems your version of a discussion is telling everyone that they're wrong "I guess that takes another level of understanding" says it all really doesn't it... nobody else's opinion counts and you know better than everyone else.GuidoK wrote:Too bad none of you want to discuss all the technical workings and mechanics of an automatic for which I gave so many hints.ronk wrote:It would seem to me that the entire army is marching out of step except one man !
- techathy
Re: Auto or manual
Yes at an intellectual level the differences between the various types of gearboxes are interesting but in the real world you get the choice of a gearbox with a clutch pedal or one without a clutch pedal. You see, most people don't give two hoots about how the gearboxes work. So you don't see 8sp auto, 7sp DCT or 6sp manual options, you'd get very confused customers wondering why you have low & high spec auto options. At driving level what I care about is that...GuidoK wrote:Too bad none of you want to discuss all the technical workings and mechanics of an automatic for which I gave so many hints.ronk wrote:It would seem to me that the entire army is marching out of step except one man !
- The DCT transmission in the Z4 35iS changes gear in a fast & crisp manner but sometimes causes harsh changes.
- The automatic in the M135 is always smooth and never makes harsh changes but can get a little soggy under certain circumstances.
- The manual in my 120dx was slightly notchy but very positive & a nightmare to change smoothly under constant speed or moderate to gentle acceleration.
Current: '09 Lotus Evora Launch Edition
Previous: '13 BMW 120dx, '15 BMW z4 35iS
- ronk
Re: Auto or manual
So now you think that those who don't agree with you don't have the same level of "understanding" as you!GuidoK wrote:Too bad none of you want to discuss all the technical workings and mechanics of an automatic for which I gave so many hints.ronk wrote:It would seem to me that the entire army is marching out of step except one man !
Maybe it's only another opinion that you don't understand!
- Garvin
Re: Auto or manual
The DCT gives you a number of options to change down a number of gears e.g. when going for a 'crisp' overtake:
1. Kick down. But if the box needs to select a couple of gears lower there is a definite perceivable delay whilst it sorts itself out before 'engaging'.
2. Manually flick the paddles. This is OK but if you change down and delay hitting the 'loud pedal' whilst you look for the correct opportunity to execute the overtake it can have reverted from 'manual' back to 'auto' and have changed back up a couple of gears. If you wait for the overtake opportunity before flicking the paddles then there can be a discernible delay - not very much but it is noticeable.
3. Use the 'stick' to put it in manual - you then have control over gear selection as you wish.
4. Use the 'stick' to go to 'sport' mode. Box changes down to select a low enough gear and holds it. Then when you want the overtake hit the 'loud pedal' and it will change down if necessary but usually only one gear and away you go with minimal delay.
It's all about learning to drive a DCT. My most often used option is No 4. On approaching a slower vehicle i just put the box in 'sport' preparing for the overtake and then nail the manoeuvre when the opportunity becomes available. Afterwards the box can be put back into normal 'auto' mode to continue the 'cruise'.
- Wondermike
- Moderator
Re: Auto or manual
I enjoy driving a manual, but the biggest difference for me now, which hasn't really been mentioned, is the ridiculously long gearing on manual cars. At least with the auto boxes, and the 8 speeder in particular, the first four ratios are pretty close and short.
One of my favourite little cars is the Fiesta 1.0 turbo, but the gearing is hopeless, third goes over 100 mph.
Part of the enjoyment of driving is taking the car to the redline, but I would prefer to have more than just 1st and 2nd available to do it without going at stupid speeds.
