My missus has her 'tash removed using electrolysis, no wonder her lip is a bit red when she gets in! [/quote]lux wrote:
You married a female Greek wrestler..?????
What do you mean, sorry - the new X6 ones, or the old ones?Z4M-2006 wrote:Stuart...........What is the outside diameter of the exhaust pipes once the trim is removed ?
Nope , because imho it's too much money for "bling". The OEM discs on the 35iS are massive (Front (348mm) and rear (324mm)), but I will look to upgrade the pads (StopTech or another top brand), change the fluid (not sure if it's dot 5.1, but will upgrade if not), and HEL Performance braided hoses.john-e89 wrote:Did you consider a BBK out of interest? It's one thing I think is sorely lacking on both the 35 models.
No idea really, but this X6 pipe has brackets on the inside which means it should spot weld on to the old pipe. It won't be fitting on like a glove, but I think they can manage.Z4M-2006 wrote:No sorry...
The ones on the car...The pipe outlet size on the backboxes
Will find out how they get on tomorrow to see if its a pain in the butt job or not. They cost quite a bit and seem very well made, plus I'm keen to keep as much BMW parts on as possible and only replace where better after market is available. Keeps the theme going tooZ4M-2006 wrote:Ah....
I was thinking of you had the outer diameter figure that there maybe other alternatives to the X6 pipes ?
Yep, stands for front mounted intercooler.john-e89 wrote:FMIC..? The intercooler yes? If so will it be a thicker core or is it bigger overall, ie, taller, wider?
