I may be being thick but confused about the difference between re-map and e-tunedR.E92 wrote:The standard maps that come with it are good for ~380bhp. If you want more then you get e-tuned for $200.
Remap 35i
Re: Remap 35i
- R.E92
Re: Remap 35i
A re-map is the base tune. An e-tune is someone tweaking the tune further to customise it to your car by using engine data logs.petrolhead wrote:I may be being thick but confused about the difference between re-map and e-tunedR.E92 wrote:The standard maps that come with it are good for ~380bhp. If you want more then you get e-tuned for $200.
So you get a basic tune, write it to the car and drive around a little with your phone/COBB AP (depending on what route you take) storing engine data via to OBD port.
You then send the log to the tuner and he will adjust the tune and send it back to you. You load it into the car and repeat the same again until the tuner is happy with the data you send back.
All cars are different and everyone is at different altitudes with different grades of fuel around the world. It's impossible to make a one size fits all tune that performs well because there are so many variables. That's part of the reason the stock map is so tame, BMW want to allow for people who own the car in countries with terrible fuel quality, high temperatures and high altitudes. For us lucky Brits we have great fuel, cold weather and most of us aren't far from sea level so we can get some seriously good power gains.
Re: Remap 35i
Many thanks, that all now makes senceR.E92 wrote:A re-map is the base tune. An e-tune is someone tweaking the tune further to customise it to your car by using engine data logs.petrolhead wrote:I may be being thick but confused about the difference between re-map and e-tunedR.E92 wrote:The standard maps that come with it are good for ~380bhp. If you want more then you get e-tuned for $200.
- SO8
Re: Remap 35i
Anyone here used DMS to remap a 35i or 35iS ?
Current : BMW M240i Convertible in black and a Smart Fortwo diesel in white
Previous : BMW 35iS in Mineral White and an Mercedes AMG A45 in black
- th30d0r3
Re: Remap 35i
I have my 35is mapped by them. Totally changes the character of the car. It's fast with 407bhp on the dyno and you can certainly tell. But it makes the car drive too aggressively, you can't really pootle about. Took them 3 attempts to get it right. Fuel definitely suffers too, regardless of what they say.SO8 wrote:Anyone here used DMS to remap a 35i or 35iS ?
I'm actually going to remove the map and pit ot back to standard, because I don't drive it enough and when I do, it's London driving so all I'm doing is burning fuel. Plus it needs a service.
Don't like my red stripes...? Then don't look at them...
- SO8
Re: Remap 35i
Thanks, this was exactly what I was looking for. Their remap of my 330d LCI was truly superb but turned it into a bit too much of a beast to pootle about in. Can you actually use all the power in the dry or does it just spin up a lot ? My 330d (different I know) was OK but only in the dry with warm tyres on a good road ... otherwise letting it short shift from 1st was an absolute necessity if pulling away from a standstill.th30d0r3 wrote:I have my 35is mapped by them. Totally changes the character of the car. It's fast with 407bhp on the dyno and you can certainly tell. But it makes the car drive too aggressively, you can't really pootle about. Took them 3 attempts to get it right. Fuel definitely suffers too, regardless of what they say.SO8 wrote:Anyone here used DMS to remap a 35i or 35iS ?
- R.E92
Re: Remap 35i
You could ask them to map the throttle in a linear fashion.
The standard BMW throttle table is mapped to give you 100% throttle at 40% pedal which is to aggressive for my taste even without increasing the power output.
Most people who tune their cars use a more linear throttle table which will give you 100% throttle at 70% pedal. It helps control the power but makes the car feel sluggish initially until you re-adjust your right foot.
- Garvin
Re: Remap 35i
This is the key issue IMHO. I have already posted that a 35is in OEM tune has problems controlling the power as it is so increasing the power is just going to exacerbate the problem. That is why it is being suggested that an LSD and decent high performance tyres are a must before remapping alone which will just result in, essentially, unusable additional oomph!SO8 wrote:. . . . . . . . Can you actually use all the power in the dry or does it just spin up a lot ? . . . . . . .
- SO8
Re: Remap 35i
You sure your 35iS isn't already mapped ! I have few issues with it as std but can feel too much more power would overcome the chassis and make the car less fun.Garvin wrote:This is the key issue IMHO. I have already posted that a 35is in OEM tune has problems controlling the power as it is so increasing the power is just going to exacerbate the problem. That is why it is being suggested that an LSD and decent high performance tyres are a must before remapping alone which will just result in, essentially, unusable additional oomph!SO8 wrote:. . . . . . . . Can you actually use all the power in the dry or does it just spin up a lot ? . . . . . . .
- Garvin
Re: Remap 35i
I'm actually agreeing with you. Mine is not re-mapped and on anything but smooth tarmac it lights up the traction warning when using WOT in first gear a little too often and gets a bit too wayward at the rear far too quickly in tight bends! On broken and bumpy surfaces the traction light flickers incessantly so I have it in sport mode and wrestle it along. Another 50 bhp or so without other changes (LSD and non RFTs) would render the car almost undriveable when trying to use all the additional performance!SO8 wrote:You sure your 35iS isn't already mapped ! I have few issues with it as std but can feel too much more power would overcome the chassis and make the car less fun.Garvin wrote:This is the key issue IMHO. I have already posted that a 35is in OEM tune has problems controlling the power as it is so increasing the power is just going to exacerbate the problem. That is why it is being suggested that an LSD and decent high performance tyres are a must before remapping alone which will just result in, essentially, unusable additional oomph!SO8 wrote:. . . . . . . . Can you actually use all the power in the dry or does it just spin up a lot ? . . . . . . .
- SO8
Re: Remap 35i
Garvin wrote: I'm actually agreeing with you. Mine is not re-mapped and on anything but smooth tarmac it lights up the traction warning when using WOT in first gear a little too often and gets a bit too wayward at the rear far too quickly in tight bends! On broken and bumpy surfaces the traction light flickers incessantly so I have it in sport mode and wrestle it along. Another 50 bhp or so without other changes (LSD and non RFTs) would render the car almost undriveable when trying to use all the additional performance!
- SO8
Re: Remap 35i
I wonder if the Cobb maps are less aggressive ... no contacting DMS every time you want the map removed either - just a plug in device to the OBD ... hmmm
Available in the UK from Litchfield who have a good reputation and can purpose map to what you want - albeit for £££ ...
I must stop thinking about something I don't need ...
- R.E92
Re: Remap 35i
The standard COBB maps are very tame but have a good reputation for support. You can get hold of used COBB APs for the N54 very cheap (£250) these days because everyone is moving over to the newly released MHD.SO8 wrote:I wonder if the Cobb maps are less aggressive ... no contacting DMS every time you want the map removed either - just a plug in device to the OBD ... hmmm
The N54 section on Bimmerpost is the place to be asking all these tuning related questions.
- SO8
Re: Remap 35i
I know but it seems mainly US based. My comments were more as chit chat this timeR.E92 wrote:The standard COBB maps are very tame but have a good reputation for support. You can get hold of used COBB APs for the N54 very cheap (£250) these days because everyone is moving over to the newly released MHD.SO8 wrote:I wonder if the Cobb maps are less aggressive ... no contacting DMS every time you want the map removed either - just a plug in device to the OBD ... hmmm
Re: Remap 35i
Been away from the forum for a while, but we've been running an ESS map for almost three years, stage 2, with no issues. Low rpm pick up is greatly improved and then there's the extra boost which is always entertaining when you feel like having fun
http://www.esstuning.com/products/ESS-E ... tware.html
