Just washed the Z, found a dent above a wheel arch, unhappy.
Re: Just washed the Z, found a dent above a wheel arch, unha
Don't worry mate - a good PDR man will sort it out - had a similar dent on the arch lip on my previous zed which was sorted no problem.
What's the likely cost?
The White dot at the middle of the photo (around 10pm on the arch) and subsequent distortion.
- Wyldie85
£60.00 ish.
Mine is going in to have 3 removed next week after some inconsiderate asses keep opening their doors on to it!
- ekimj10
Paintless Dent Removal all seem to be around the £50-£60 for a small one like yours, they do seem to perform minor miracles though.
Best of luck.
Best of luck.
2.2R Toledo Blue
Got a couple of similar ones on mine which i will sort once its back from an insurance repair. One side will be completely fresh so will need to have the rest detailed and brought up to scratch.
Simon's Ruby Black Z4 MC Journal
viewtopic.php?t=70563
E36 M3 Evolution - Individual Journal
http://www.bmwowner.com/forum/viewtopic ... 6&t=209427
The closer you are to death, the more alive you feel!
- Machine monkey
Or if you feel brave... Use a hair dryer to warm the area. Use a hair dryer not a heat gun as you could damage the paint.
Then hold a compressed air canister. Like you would use for dusting a keyboard. upside down and freeze the area. Repeat a few times. You might get lucky and the dent will be gone for an hours work and a few quid.
I have had mixed success with the above technique.
Good luck fingers crossed
Well she's washed and all tucked up now so I'll have to sort a dent man soon...
Untitled by GaryThomlinson, on Flickr
- Bing
Because of where it is I'd guess that's easy fixed - I had one on the top of the arch on my last Z and it was gone in 10mins for £40. Make sure you watch when they do it, it's like sorcery the way it disappears
Current... Silver Grey ///M Roadster, non-flimper spec, Imola Red nappa, permanent ear-to-ear grin
- maxman
I had a similar size dint on the front wing,a local chap removed it £40.You can't tell were the dint was .
I know how you're feeling. Had to get 3 similar sized dents removed from passenger door last year.
Used Dent Wizard. £60 to remove all 3
Replacement: 2018 M240i Auto Convertible with plenty of options
Previous
2013 E89 Valencia Orange 20i sDrive Auto
2007 E85 Monaco Blue 3.0si
2003 E85 Sterling Grey 2.5i
Previous
- srhutch
- Moderator
My bloke only charges me £20
But that will be an easy fix Maniac.
What annoys me is its been on the drive for a week and I'm sure the dent wasn't there when i put it there. Fairly sure it was fine then. My guess is someone's walked past it and whacked it with something.
- TitanTim
Had mine done by Dent Devils through my local bodyshop for 75 quid.
Before.
After,
All done using a puller as there was no access from behind the door. Its not 100% perfect but was either as is or finding a replacing door the same colour or fill and respray which would have been impossible to get a colour match.
Tim.
Before.
After,
Tim.
