Stop digging nowsars wrote:Lol, yes engines are geared down, but a diesel is less geared down than a petrol, but not higher geared which means geared up, but yes higher geared down.....no that doesn't work either
Regards
^ exactly what makes diesels ultimately less "fun" to drive (that and the noise).sars wrote:No, torque and power are stated at the flywheel, not at the driven wheels so it is not just a function of torque it's also about gearing, a reduction gearbox increases torque but not power ( remember power = torque x rpm/5252)
A turbo diesel produces lots of low down torque, however they do not produce high rpm and thus the gearing is slightly lower to allow for the reduced rpm. Thus the torque generated at the driven wheel is usually less than its petrol bhp equivalent.
Hence modern 7 or 8 speed autos on Diesel engines are so good
I've used data taken from real dyno pulls to generate this is thrust to weight ratio graph. As you can see the 28i spends most of it's time above the 3.0si except for right at the top end of the rev range.RX-78 wrote:Thanks tech, I kinda get it. I think
Because the acceleration (0-60mph) is an average of acceleration that took place, acceleration at the point of max torque may not be the same in both car? And therefore my calculation is fundamentally flawed?
Enough of the variables are constrained that simplistic works here & I was trying to keep it simple for someone who hadn't quite got the concepts sorted in their headsars wrote:That's to simplistic and using power to describe acceleration is inaccurate, acceleration of an object is governed by it's mass and the amount of force applied to it, in other words the amount of torque at the driven wheel gives you the force. and then, well there are just so many factors that can shape the acceleration curve of a car, gear ratios, number of gears, spacing between gear ratio's, final drive, driven wheel diameter, tractability, engine torque curve, maximum rpm and etcetera
It completely falls on its arse past 5k!Twin Turbo wrote:As always techathy, great valuable input.
However this I believe will slightly change the perspective
As the torque figures have increased from 258 lbs @ 3300 to 275 @ 2900
And the green line - standard is very simular to the Manufactures guidance
With a 7k red line good 0-60 gears fall out of the woodwork for cars in the 250-350Nm range & 6 speed boxes. Lower the red line/limiter 500rpm and the gearing puts them a little bit bellow 60mph/100km/h.sars wrote:... and how both cars are clearly geared for good 0 to 60 times
Yestechathy wrote: TT, that still looks fairly rubbish torque wise. Was that a JB4?
That's a bit of a naive statement, if you had a slightly lower max rpm, engineers would alter the final drive to compensate. Designers work with what they have, low 0 to 60 times is marketing desirable and so they develop accordingly. For example you can see this philosophy between the 3.0si e85 and the 3.0 e89 in the 0 to 62 times, the e89 is heavier but the time taken for the 62 dash is identical for the manual with the same engine, the 28i manual has also identical 0 - 62 acceleration @ 5.7 secondstechathy wrote:With a 7k red line good 0-60 gears fall out of the woodwork for cars in the 250-350Nm range & 6 speed boxes. Lower the red line/limiter 500rpm and the gearing puts them a little bit bellow 60mph/100km/h.sars wrote:... and how both cars are clearly geared for good 0 to 60 times
