Does anyone know how this comes off.
Does it use the usual push on fittings.
Need to remove as i am sure there is something loose that starts tapping when I drive over a rough road.
Also I have now put dirty finger marks on it.
What an awful surface material to try and clean.
Rear cabin roof liner
Re: Rear cabin roof liner
Thanks, should have spent a bit more time searching.
I keep meaning to get this tool myself as I'd like to remove the liners to check the roof dampers concealed within, in summer the rear clamshell wobbles a bit around the midpoint and I'm fairly sure there are dampers underneath which might need adjustment.
I just pulled these panels off on my old Z4. Start with the front one then the back.
I just don't know what the connectors look like and I'd hate to pull and damage something, like a connector snaps and I end up with more rattles.jwa1 wrote:I just pulled these panels off on my old Z4. Start with the front one then the back.
I was hoping just to pull off a few near the forward edge and peer behind to see what goes on.
Always fancied something like this;
http://www.gizoo.co.uk/Products/SnakeScope.htm
Just ordered this, worth a try;
http://www.ebay.co.uk/itm/5M-7mm-6-LED- ... 58b1ad2b89
