Parking sensors not working and I'm 4 hours from BMW
Hi guys,
As the title suggests my parking sensors on my 2010 Z4 are not working. Something I didn't realise or think about when I test drove the car.
Anyways, I'm unfortunately about 3-4 hours away from the nearest BMW garage. I've read some threads which show parking sensors are fairly easy to replace after you remove the cars bumper.
However, they also state that there should be some clicking or sound from the sensors. I have no sound at all. Nor is there any 'beep' when the car is put into reverse.
Any help on what else I may be able to check (blown fuse or something somewhere?). Cable not connected?
- hopz121
Re: Parking sensors not working and I'm 4 hours from BMW
Have you checked the fuse?
Ash
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
Thanks for the reply.
Unfortunately I'm not really a car person so wouldn't know where to look for that.
I'll do some Googling.
Open to any other suggestions.
- hopz121
If you look in your manual, you should have a fuse box loaction and diagram allowing you to find the fuse box and correctly locate the correct fuse, remove the fuse and look for a break in the wire.
Ash
Ash
- dr_john
If none of the sensors are working then it's very unlikely to be problem at the sensor end, more likely a switch, fuse, or loose connection.
I wouldn't consider removing bumpers until all other possibilities are looked at.
Sapphire Black G29 2.0 MSport with Technology pack
Thanks John!
After I've checked the fuse is there anything else you recommend looking at?
- envy
is there not a local garage you could take the car to. would save you a lot of time and hassle especially if you are not very technical yourself
- dr_john
Yeah, agreed. It doesn't have to be a BMW garage to diagnose what sounds like an electrical connection problem, any competent garage should be able to do that.envy wrote:is there not a local garage you could take the car to. would save you a lot of time and hassle especially if you are not very technical yourself
- sohail360
This might be obvious but you know that the sensors only become active when the its put into reverse. They then stay active even in 1st until a specific speed.
Black 35i DCT
- Angie4m
That's assuming he has rears only as if you have front and rear they can be activated by the PDC button next to the roof buttons.sohail360 wrote:This might be obvious but you know that the sensors only become active when the its put into reverse. They then stay active even in 1st until a specific speed.
However yes if only rears they will only be active when in reverse. So he'd need someone in the car with their foot on the brake to check
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Current:
Protonic Blue i8
Amethyst 997
I know they're only active in reverse, yes
I had a friend put it into reverse while I went to the back of the car. Appreciate the replies. Fingers crossed I can find a decent garage in Thailand.
