Headlamp washers
- awwalker
Re: Headlamp washers
you know what.... I wouldn't bother, can't really see how it can wash off the crud without a wiper anyway!
- Angie4m
It's a MOT fail that's why I would like to bother. If I don't attend to it, it won't get better. I've never had an issue with any other headlamp washers, even my 2003 E46 still works perfectly.
I know they clean jack all really but if they are fitted they must be tested and if not working it's a fail
Deep Sea Blue sDrive35is - I LOVE IT! Best car I've ever owned - Gone
RRS V8 Supercharged - Gone
Abarth 595 Competizione - Gone
Yas Marina Blue M4 Coupe - Gone
Current:
Protonic Blue i8
Amethyst 997
F56 JCW Challenge (19 of 52)
Still Shy and retiring
Current:
Protonic Blue i8
Amethyst 997
- Jembo
Evening Angie4m - I took the fuse out of my Z4 headlamp washers as I got miffed off with the water spraying all over my shiney bonnet.Angie4m wrote:It's a MOT fail that's why I would like to bother. If I don't attend to it, it won't get better. I've never had an issue with any other headlamp washers, even my 2003 E46 still works perfectly.
So, did you buy it new or 2nd hand, as if so the previous owner might have removed the fuse - every MOT it went for never showed up as a fail, so hope for us all though u a right it's an MOT failure
Lifer 54
Lifer 54
- Angie4m
I bought used from BMW at two years old and when I checked with them confirmed that they 'checked' the headlamp washers which I doubt, I did think maybe it was the fuse but no. I'm sure my local Indy isn't that bothered about checking them. Just a bit annoying but not as annoying as when they spray the bonnet. It's a no winJembo wrote:Evening Angie4m - I took the fuse out of my Z4 headlamp washers as I got miffed off with the water spraying all over my shiney bonnet.Angie4m wrote:It's a MOT fail that's why I would like to bother. If I don't attend to it, it won't get better. I've never had an issue with any other headlamp washers, even my 2003 E46 still works perfectly.
I just don't like the dealers as each time my car has been returned it's been damaged in some way, washed even thought i ask them not to, once it was covered in muddy water marks and they always seem to use half a tank of fuel road testing it even when the item doesn't require road testing ie fixing a dodgy boot latch
Next time I'm buying new again....not that it solves much apart from I know how it's been treated and costs me a fortune as I do less than 2k a year at most. But the car was mint when I bought it, just like the one I traded.
Good to know yours have passed, given the amount of people with aftermarket xenon and HID kits going about its clear these aren't being checked as they should be a failure too.
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
- Angie4m
The other reason I was curious was because the E46 does it every 3 sprays. I'm off work on Friday to get the tracking and alignment done so I'll have another bash at seeing if I get it to work. Might get it up and check filters etc. that's if I can stop driving it as I'm hoping for roof down weather for once!
Thank you for all your help guys, you are MUCH more helpful than a manual
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
Onlineronk
My dealer gave me the warnings about non BMW screen wash additives some time ago!Angie4m wrote:Issue I have is the car has done 500 miles since January mostly during the day and the weather has been kak up here, constantly raining so I've not had any real reason to use the headlamp washers so I thought I'd give them a go and nope, nothing. Strange there was little fluid in the bottle so I filled it.
Now thinking I should possibly siphon off the 6l of water and washer fluid I've put into the tank and fill it with warm water, take it a drive, siphon it off then try putting warm water around the system to maybe breakdown any kak. Failing that it's a trip to the stealers. I'm not a huge fan of the two I can use hence buying from another dealer in Newcastle and leaving it with them for a whole day fills me with dread.
I know many on here have said they have used alternatives without problems, but it makes you wonder if there may be some additives that do bung up the filters???
- Angie4m
You would think it was a scare tactic but I have read that mixing different solutions can cause this issue another reason I think I should siphon it off and start again as I only currently have bmw screen washronk wrote:My dealer gave me the warnings about non BMW screen wash additives some time ago!Angie4m wrote:Issue I have is the car has done 500 miles since January mostly during the day and the weather has been kak up here, constantly raining so I've not had any real reason to use the headlamp washers so I thought I'd give them a go and nope, nothing. Strange there was little fluid in the bottle so I filled it.
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
- markeg
Headlamp washers
I heard that the cause is using surfactant products (usually the summer screen washes) rather than the alcohol-based products (usually winter washes). The gunk that fouls up the pumps and lines is, I believe, bacterial based; with winter mixes the alcohol will kill anything in there...but if there is bacterial growth, the residue will remain.
Personally, I have always used the Halfords "pink" brew in #108 and have done since I've owned her. There isn't any gunk in the bottle.
In my experience, garages (and I include dealers in this) also top up the screen wash with ionised water - I've certainly seen this happen ...
previous: Alpina Roadster S, #108: gone
current: MB C-class
"veni, vidi, velcro - I came, I saw, I stuck around..."
current: MB C-class
- jimmybell
Just to confirm it is an MOT fail if they don't spray "correctly".
It's a reasonably common problem, the lines get gunky or the filters do, meaning there's not enough pressure to raise the arms to spray. They're actually pretty easy to disassemble and clean.
Some arms also break (i had this), so need replacing. If you have warrantee it should be fine, but if not - do it yourself, its really not too hard, but it does involve bumper off and a part from Sopers @ Lincoln
V12 Vantage S - Hammerhead Silver, Manual, Lightweight Wheels, Exterior Carbon++, Carbon Buckets, AMR Performance Pack.
M135i LCI - ZF8, White, HK Audio, Adaptive
GONE Z4 M Coupe, Imola, CSLs
GONE C63 AMG, Black, Performance Pack+, LSD, HK
Onlineronk
So the BMW fluid might not be that expensive in the long run if you take a garage job to clear the pipes??
- pvr
After having seen the issues the E53 X5 owners had with non BMW cleaner in the washing bottle, I have bulk bought the BMW fluid. Smells better as well
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Angie4m
Cheers guys. Fingers crossed that this weekend is nice and I can have a look myself, if I can't see anything then I will take it to the dealers to deal with under warranty.
Oh and yes I've heard the BMW stuff smells quite nice, i've never noticed myelf. Might sniff the bottle again tonight
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
Onlineronk
Don't want to rain on your parade but the dealer said it wouldn't be a valid warranty claim due to non BMW approved product being used.Angie4m wrote:Cheers guys. Fingers crossed that this weekend is nice and I can have a look myself, if I can't see anything then I will take it to the dealers to deal with under warranty.
- Angie4m
Well they would need to prove it as I bought it in January from Lloyd Newcastle and only done 500 miles since purchase. Lloyd Newcastle have assured me that these washers were checks prior to pick up by me. I've only put in bmw washer fluid and evian water last week when I noticed they didn't work and it took about 4.8 litres of water so either they didn't check them or I've had a leak of quite a lot of fluid, which has subsequently cured itself . Highly doubt they were checked as I would have expected a lot more than 1.2 litres in a 6 litre tank.ronk wrote:Don't want to rain on your parade but the dealer said it wouldn't be a valid warranty claim due to non BMW approved product being used.Angie4m wrote:Cheers guys. Fingers crossed that this weekend is nice and I can have a look myself, if I can't see anything then I will take it to the dealers to deal with under warranty.
As I only have BMW products for my car it's not me and if it turns out it wasn't covered I'd be taking them to court over their claims they checked them prior to pick up as I highly doubt they just stopped working given the little water there was in the tank, I would have thought there wasn't enought water to allow the pressure needed. Bit harsh but I didn't expect a approved car to have an issue like this. The car had been well kept and was immaculate but if it hadn't been for me wondering I would of never known until???? As I don't tend to drive at night and during the day the lights aren't on.
Current:
Protonic Blue i8
Amethyst 997
Current:
Protonic Blue i8
Amethyst 997
Onlineronk
Please let us know the outcome!
