Brakes and Fluid Change Questions
- DinosaurEyes
I'm going to get brake fluid and pads etc changed on my 2010 E89 35IS.
1. Any recommendations for brake fluids? This is my current choice. Motul RBF 600
2. How much fluid should I buy for a full flush? 1 litre?
3. Any brakes discs or pads recommendations? I've never bought new brakes before so have no clue on brands and so on, so any recommendations / personal opinions on the topic are welcome. Not sure I even need discs, but interested to know your thoughts.
Thanks in advance, and sorry for not reading the manuak, but I like getting up to date thoughts from the community.
- ph001
Any DOT5.1 fluid will be good. It has a higher boiling point than DOT4. Don't use DOT5 though - it's not compatible.
For brakes - have you ever suffered brake fade on your current setup? Your answer will make a difference to my recommendation.
- Kugaman1
If dot 4 is factory standard, why isnt dot 5 compatible?
I was going to refresh mine in the spring and Ive got 2 bottles of dot 5 in the garage!
- jabber
Dot 5 is silicone based and must not be mixed with other fluids
Z less again
- ph001
Indeed. Plenty of people have made that expensive mistake in the past... which it sounds like we might have just saved you from . DOT 5.1 is the right one to use if you want an upgrade from DOT 4..
- Kugaman1
WOW, had no idea, thanks guys!!!
Dodged a bullet there I think!
It should say on the tin/bottle!!
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Kugaman1
Phew.....
Not as bad as thought.....just went out to the garage to check.....mines actually 5.1 so not the disaster it might have been....
Not always true, some DOT4 have higher BPs than DOT5.1 the rating also includes a viscosity limit too, so if you want the highest BPs available don't confine yourself to DOT5.1.
That's assuming that DOT4 is an approvied fluid for the E89.
- DinosaurEyes
Nope no brake fade.
My mum just poured washer fluid into her brake fluid reservoir last night and it reminded me i need to get mine looked at, they are just soon to be due a service according to the in car info.
- Gaffa22
Oops will need to get that out then
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
2016 Honda VFR1200F
- DinosaurEyes
- Gaffa22
Yes just suck the fluid out with a turkey baster and re fill with brake fluid
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
- ronk
I would say have it changed from the calliper nipples - theres no telling how far down the pipes its gone!
- Gaffa22
I'd still empty the res first. And yes a full fluid change would be best.
But if the car hadn't been driven would the fluid move round the system at all ?
2010 E89 35i DCT
2016 Honda VFR1200F
2016 Honda VFR1200F
