How many gears should the DCT kickdown?
- sunnydays
Hi guys,
So my 35is, under heavy acceleration (not quite pushing down the kickdown, and when pushing down the kickdown) is going down from gear 5 @ 40mph to gear 2....
Now im pretty sure it normally only goes down 1 gear, ie gear 5 to gear 4.
Can someone confirm my logic is correct and im not going bonkers?
Gearbox knows best - apparently!!!!
Mark
Plymouth
E89
35i
Carmine Red
Black leather
Plymouth
E89
35i
Carmine Red
Black leather
- Gaffa22
Had mine go from 7 down to 3 the gear is determined by the revs
If you bury the throttle at around 65-70 it will change down to 3rd
If you use the paddles or shifter it will only go up or down 1 at a time
2010 E89 35i DCT
2017 Honda CBR1000RR fireblade
2016 Honda VFR1200F
2016 Honda VFR1200F
It'll drop down enough gears to give maximum acceleration for the given amount of throttle regardless of initial speed.
- Ducklakeview
+1 - What he said, that's the beauty of these dual clutch boxes, they can "jump" a selection of gears almost instantaneously.
Mike
There’s a difference between foot to the floor and kick down. The latter as above is max acceleration and the former a mix of power and economy.
At 4,000 revs in 5th, for example, in Sport/S (i.e. gear lever to the left), hard kick-down keeps me too busy to count gears.
Vidi, vici, veni
- sunnydays
Thanks for the confirmation everyone. So if I understood correctly in auto mode it will kick down to the lowest possible gear. In manual mode it will kick down 1 gear. Which is probably why i was thinking it only jumps down 1.... lol
Kick down will always drop down enough gears to give you max acceleration, regardless of which more you are in.
Z4 S-Drive 35i
Audi TT S-line
Mazda MX5 Mk2.5 (for sale)
Wokingham Berkshire
Audi TT S-line
Wokingham Berkshire
- Paulr
They are governed so they will not self destruct by chucking themselves into first at 80. You cannot put them into reverse whilst going forward either. If you test that and it does go into reverse, I will deny everything.
If you try and take a cat apart the first thing you have is a non working cat.
