Buying through AUC - brake disc minimum
bensz4mc
Post by bensz4mc » Fri Oct 06, 2017 9:08 pm
I am looking at a 35is at Synters and they have told me the brake discs are fine, the thickness is:
Front - 28.7mm
Rears - 18.6mm
What do you think?
Ducklakeview
Post by Ducklakeview » Fri Oct 06, 2017 9:34 pm
This any help?
Mike
bensz4mc
Post by bensz4mc » Fri Oct 06, 2017 9:49 pm
Thanks - so if I am reading right the fronts have .3mm left and rears .2mm left. How much life/miles is this likely to give me?
Ducklakeview
Post by Ducklakeview » Fri Oct 06, 2017 9:54 pm
How are the pads? I ask, as if you look there is a higher min thickness specified. I presume this is because both that new pads will wear the disc more as they bed, and they prob won't get inspected again for some time after new pads..
Give me 2 mins and I'll check Autodata again and see if a min pad thickness is specified.
Mike
Ducklakeview
Post by Ducklakeview » Fri Oct 06, 2017 9:57 pm
Sorry, just noticed the min pad spec is also above. See if they are below the spec, in which case, following the above, it will need new pads AND discs.. But your discs are also above the mins for requiring replacement even if the pads are past it, if that makes sense..
You have 0.9mm on the front discs, and 1.0mm on the rears
Mike
bensz4mc
Post by bensz4mc » Fri Oct 06, 2017 10:49 pm
The pads are 10mm.
I thought the minimum thickness are Fronts 28.4mm and Rears 18.4mm
Ducklakeview
Post by Ducklakeview » Fri Oct 06, 2017 11:12 pm
No, it's 27.6 & 17.6 during a standard measurement. The other figures are for measurements taken when the pads are being replaced. If the pads are 10mm, then it's safe to assume recent replacements, at which time the discs would have still been above the higher thickness figures specified for replacement.
Mike
bensz4mc
Post by bensz4mc » Fri Oct 06, 2017 11:54 pm
Great thanks! So there is quite a bit of life left on them then..
Ducklakeview
Post by Ducklakeview » Sat Oct 07, 2017 12:33 am
I'd say so..
Mike
bensz4mc
Post by bensz4mc » Sat Oct 07, 2017 12:37 am
Thanks allot Mike!
