Key Fob Roof Down
Smartbear
Key Fob Roof Down
Post by Smartbear » Wed Sep 27, 2017 11:36 pm
DinosaurEyes wrote: Wed Sep 27, 2017 9:54 pm IT HAS A RECHARGEABLE BATTERY? No way! I've just been using regular ones in mine! Haha! :oops:
Hi, some models use normal batteries-comfort access ones I think?
e85 3.0si sold
superduperredz4
Key Fob Roof Down
Post by superduperredz4 » Thu Sep 28, 2017 9:46 am
ph001 wrote: Wed Sep 27, 2017 10:28 am You could confirm that either way but sitting in the car and trying to open the roof in the normal way with the centre console button...if it works it's not a battery voltage issue. I can't help thinking it's a key issue..maybe the battery in the fob is not holding charge well so you get enough power for a blip (like and unlock etc) but the sustained signal required to open the roof kills the battery pretty quickly. Bit of a guess but plenty of places will replace the battery for you included the well respected forum member ducklakeview for very little cost.
Not the replaceable type,they are supposed to be rechargeable when used in the ignition,have tried both and it still does not work.They look like sealed units ,key fobs that is.So how do you charge them up long term without driving to Scotland and back.Been told to attach trickle charger to car battery then put key fob in ignition in the on position and leave it for a good long time like over night maybe and then it will be charged up ,is this true?
Have a nice day.
geordie_zed
Key Fob Roof Down
Post by geordie_zed » Fri Sep 29, 2017 10:49 am
Don't want to hijack the thread but if your key puts the roof down when you press and hold the unlock should it also go back up when you press and hold lock ?
Am I missing something or needing to set something to make the close work ?
TIA,
Charles.
EEK my MPG is currently: Image
ph001
Key Fob Roof Down
Post by ph001 » Fri Sep 29, 2017 11:57 am
No close option as std I'm afraid. You need an aftermarket module for that.
ronk
Key Fob Roof Down
Post by ronk » Fri Sep 29, 2017 3:18 pm
ph001 wrote: Fri Sep 29, 2017 11:57 am No close option as std I'm afraid. You need an aftermarket module for that.
Smarttop Module :thumbsup:
Not cheap - but worth it in my opinion. Keep your eyes on the for section.
superduperredz4
Key Fob Roof Down
Post by superduperredz4 » Fri Sep 29, 2017 4:09 pm
Both key fobs have stopped opening the roof.Both key fobs do everything else.So what is happening to my car? Top button on both fobs unlock the car middle button locks the car ,bottom button opens the boot.Car battery fully charged up using CTEK on recon program.From now on I will just have to open the roof from inside the car instead of the flash way of walking towards it,so be it.
Have a nice day.
ronk
Key Fob Roof Down
Post by ronk » Fri Sep 29, 2017 4:39 pm
superduperredz4 wrote: Fri Sep 29, 2017 4:09 pm Both key fobs have stopped opening the roof.Both key fobs do everything else.So what is happening to my car? Top button on both fobs unlock the car middle button locks the car ,bottom button opens the boot.Car battery fully charged up using CTEK on recon program.From now on I will just have to open the roof from inside the car instead of the flash way of walking towards it,so be it.IMGP0348-001.JPG
Invest in a Smarttop !
Zed Five
Key Fob Roof Down
Post by Zed Five » Fri Sep 29, 2017 8:58 pm
Or comfort access option.
Why is it that people who can't take advice always insist on giving it?
E89 35is | BMW S1000rr Motorsport Ed.
ronk
Key Fob Roof Down
Post by ronk » Fri Sep 29, 2017 9:39 pm
Zed Five wrote: Fri Sep 29, 2017 8:58 pm
Can this be retro fitted ?
Zed Five
Key Fob Roof Down
Post by Zed Five » Sat Sep 30, 2017 5:13 pm
ronk wrote: Fri Sep 29, 2017 9:39 pm
Probably. But expensive. New door handles, column, key etc etc. May at well just buy a smart top as others suggest.
(Unless you fancy a project) :).
ronk
Key Fob Roof Down
Post by ronk » Sat Sep 30, 2017 5:47 pm
No thanks !
I’ll stick with the Smarttop module : :thumbsup:
I bought my car at the end of the production run last year so I was very choice restricted and had to accept a pre ordered car - fortunately it had most of the toys I needed but not comfort access or headlight assist!
Zed Five
Key Fob Roof Down
Post by Zed Five » Sun Oct 01, 2017 7:46 pm
ronk wrote: Sat Sep 30, 2017 5:47 pm No thanks !
Don't worry. The headlight assist on the Z4 is absolutely rubbish. I considered asking for a refund on the cost. Yes, it works, but it is crap.
Northotheborder
Key Fob Roof Down
Post by Northotheborder » Sat Oct 07, 2017 9:25 pm
Had my e89 in at the local dealers today for an oil and brake fluid change. Both my fobs now don't lower the roof, apparently the fob needs reprogramming... an hours labour £90, think I'll add some pennies and get a smart top instead!
ronk
Key Fob Roof Down
Post by ronk » Sat Oct 07, 2017 10:53 pm
I would say the most versatile way of doing things!
Function  1 = 1 on
Function  2 = 1 one touch buttons
Function  3 = 1 windows up
Function  4 = 4 25mph
Function  5 = 1 One touch windows up
Function  6 = 4 mirrors fold on lock / unlock
Function  7 = 2 unlock doors ign off
Function  8 = 0 switch invert
Function  9 = 0 seq unlock
Function10 = 0 fac window remote
