Secondary cat delete
Thinking of taking out the 2nd cat'anti get a better exhaust note. From what I've read this didn't affect emissions as no sensors there. Those who've done this what's your experience on exhaust Sound, pops on in over run .how much am I looking to get thisbdkne amd if any garages in London area you'd recommend
Last edited by rhapsodicboom on Sun Aug 20, 2017 11:26 pm, edited 1 time in total.
- Silverzedtom
Secondary car delete
Have you already changed anything on the exhaust system?
If you have a facelift zed then consider a back box delete?
I've had mine chopped out and im really happy with it.
E85 2.5si
F55 Cooper S
F55 Cooper S
Onlinebuzyg
- Ducklakeview
Removing the secondary cats alone won't give you much, as the backbox will still filter it out - BUT, as Greg posted above, I can help you with thatrhapsodicboom wrote: ↑Fri Aug 18, 2017 6:18 pm Thinking of taking out the 2nd cat'anti get a better exhaust note. From what I've read this didn't affect emissions as no sensors there. Those who've done this what's your experience on exhaust Sound, pops on in over run .how much am I looking to get thisbdkne amd if any garages in London area you'd recommend
On mine, I have one of my modded boxes and have also removed the internals from the sec cats, so the car still appears std from underneath. If you remove the sec cats completely, you'll prob get an MOT fail.
Mine sounds like this BTW..
Mike
Your neighbors must love youDucklakeview wrote: ↑Sat Aug 19, 2017 10:45 amRemoving the secondary cats alone won't give you much, as the backbox will still filter it out - BUT, as Greg posted above, I can help you with thatrhapsodicboom wrote: ↑Fri Aug 18, 2017 6:18 pm Thinking of taking out the 2nd cat'anti get a better exhaust note. From what I've read this didn't affect emissions as no sensors there. Those who've done this what's your experience on exhaust Sound, pops on in over run .how much am I looking to get thisbdkne amd if any garages in London area you'd recommend
Mike
Mines the 3.0si , i had a read through your post and sounds good. Do you have different "settings" when modding the box depending on what sound you want. Initially i was thinking that getting rid of the secondary cats will add pops and a bit of rumble but i think youre mod is the solution. Ill drop you a pm soon.Ducklakeview wrote: ↑Sat Aug 19, 2017 10:45 amRemoving the secondary cats alone won't give you much, as the backbox will still filter it out - BUT, as Greg posted above, I can help you with thatrhapsodicboom wrote: ↑Fri Aug 18, 2017 6:18 pm Thinking of taking out the 2nd cat'anti get a better exhaust note. From what I've read this didn't affect emissions as no sensors there. Those who've done this what's your experience on exhaust Sound, pops on in over run .how much am I looking to get thisbdkne amd if any garages in London area you'd recommend
Mike
- Ducklakeview
Yes, I can do std mod like mine or Marlon spec, 40% louder, also as per the box I did for Flyingfiferrhapsodicboom wrote: ↑Sun Aug 20, 2017 11:35 pmMines the 3.0si , i had a read through your post and sounds good. Do you have different "settings" when modding the box depending on what sound you want. Initially i was thinking that getting rid of the secondary cats will add pops and a bit of rumble but i think youre mod is the solution. Ill drop you a pm soon.Ducklakeview wrote: ↑Sat Aug 19, 2017 10:45 amRemoving the secondary cats alone won't give you much, as the backbox will still filter it out - BUT, as Greg posted above, I can help you with thatrhapsodicboom wrote: ↑Fri Aug 18, 2017 6:18 pm Thinking of taking out the 2nd cat'anti get a better exhaust note. From what I've read this didn't affect emissions as no sensors there. Those who've done this what's your experience on exhaust Sound, pops on in over run .how much am I looking to get thisbdkne amd if any garages in London area you'd recommend
Mike
recently, and anything inbetween.
Mike
- Player 1
If wanted, I do have a pair of 2.5/3.0i secondary decat pipes made up and ready to go?
At they moment they're cut just before where they'd meet up with the resonator so there's plenty of space to fit them up to your existing muffler.
The annoying bit of actually getting the cats out though is all done and are welded back up
- Flyingfifer
Il get a video of mine over the weekend to demo the soundDucklakeview wrote: ↑Mon Aug 21, 2017 12:09 am Yes, I can do std mod like mine or Marlon spec, 40% louder, also as per the box I did for Flyingfifer
Mike
P.S. thoroughly recommend DLVs box mod!
2006 3.0Si Coupé in Monaco Blau with all the optional trimmings
The 3.0si (N52) Euro spec engines do not have secondary cats, only a front silencer and Cats in the headers only so you should have no issues removing it, I've had mine removed and a SS system put in.
http://www.realoem.com/bmw/enUS/showpar ... Id=18_0653
However as Mike has pointed out his back box mod will give you all the pops and bangs you desire without the need to mess around with the front silencer.
I've compared my SS system to one of mikes modded back boxes and I have to admit the modded back box is far superior sounding to mine.
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
- Ducklakeview
Thanks for the comparison!Chris1981 wrote: ↑Wed Aug 23, 2017 10:52 am The 3.0si (N52) Euro spec engines do not have secondary cats, only a front silencer and Cats in the headers only so you should have no issues removing it, I've had mine removed and a SS system put in.
Mike
I've done a front silencer delete, replaced wiyh straight pipe. It's a subtle improvement, some quite muted pops on overrun but now I'm wanting a bit more i think... Cost me 100 quid all in.
