Oil warning
Oil warning
In there any info on how/where the low oil level light works or sensor is located. I think mine is playing up a bit s it keeps being when I turn the car off but the level is fine
Proud Whip owner
- buzyg
Oil warning
Amber at start and shut down, don't panic check and top up.
Amber constant, top up now.
Red you should have topped up now get your cheque book out.
///M has a dip stick. Not sure for other engines.
- Smartbear
Oil warning
Hi, I think the oil level sensor is located in the sump-not sure if it's a sump off job to replace it though?
e85 3.0si sold
Oil warning
For the OP - which engine do you have?
For the N52, I don't *think* it's a sump off job but it would certainly be a dump the oil job:
http://www.realoem.com/bmw/enUS/showpar ... Id=11_3834
Oil warning
M54...
I'm pretty religious at checking and this car has always prefered having the oil level closer to the full level on the stick than closer to the bottom so when it does the yellow at shut down I'm not too worried. Often short journeys will cause a yellow. But recently it's been at the end of long drives or when (ironically) in driving gently
Proud Whip owner
Oil warning
How do you know the oil level is ok, digital readout on dash or a manual dipstick? Mine (3.0si N52) is digital and gives a warning light when there are no bars or 1 bar... my M3 was a dipstick and would put a light on when just the level was less than half, it might just be a bit 'sensitive' what level do you get when you switch the car off?
I think they slot into the oil sump from underneath with 3 bolts so should be pretty easy to swap out if need be, but you'd definitely want to drop the oil first!
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
Oil warning
manual dipstick. its about half too. its due an oild change so ill prob just do that and top up to the top of the stick and maintian that. it only gets used for short journeys at the mo if at all ... stark contrast to usually only doing 120miles of motorwayChris1981 wrote: ↑Mon Jul 24, 2017 10:58 am How do you know the oil level is ok, digital readout on dash or a manual dipstick? Mine (3.0si N52) is digital and gives a warning light when there are no bars or 1 bar... my M3 was a dipstick and would put a light on when just the level was less than half, it might just be a bit 'sensitive' what level do you get when you switch the car off?
Proud Whip owner
- step_change
Oil warning
I do not like the digital method with no dip stick at all. I have that on mine. Much rather measure it myself with a dipstick.
Gone : 2013 35is, Melbourne Red, DCT, Nav, Comfort pack
Gone: 2007 2.5is, Montego Blue, Auto, Nav
- TR4man
Oil warning
If it is half way between minimum and maximum on the dipstick, then that is fine isn't it? Perhaps it is just the sensor that is at fault? Just be wary about trying to fill to the maximum mark as it is easy to overfill and too much oil has its own problems.domsz4 wrote: ↑Sat Jul 29, 2017 11:04 ammanual dipstick. its about half too. its due an oild change so ill prob just do that and top up to the top of the stick and maintian that. it only gets used for short journeys at the mo if at all ... stark contrast to usually only doing 120miles of motorwayChris1981 wrote: ↑Mon Jul 24, 2017 10:58 am How do you know the oil level is ok, digital readout on dash or a manual dipstick? Mine (3.0si N52) is digital and gives a warning light when there are no bars or 1 bar... my M3 was a dipstick and would put a light on when just the level was less than half, it might just be a bit 'sensitive' what level do you get when you switch the car off?
2006 E86 Si Sport as a daily driver.
